Question about Pentair MASTER TEMP HEATER 400 000 BTU NG LOW NOX HD EXCHANGER
My wife said the pump timed off and the heater was heating. She shut the heater off and restarted the pump and now the heater won't ignite. The red light blinks three times and I am not sure how to get it to heat again.
  • 44 Answers
The fan will continue to run for a few minutes after the pump turns off to purge exhaust gasses.If it was still heating you have a problem. To reset the heater,turn off the pump breaker for 30 seconds. After that you need a repairman.
Posted on Sep 28, 2010
Heater fan on electric fireplace not working, so heat shuts off and won't come back on. The manufacturer is Southern Enterprises, Inc., model no. FA515500TX.
Was having same problem, found the fan needed a little oil on bearings. Was not spinning up to full speed so heater was cylcing on high limit
Jan 21, 2013 | Southern Enterprises Luxembourg Ivory...
New jandy LxI 400 natural gas pool heater makes a howlering sound which starts after it runs for about five minutes. The noise starts soft and continues to get louder. The noise is loud. Once I shut the...
Your bypass valve is bad. Probably because you did not pay attention to your water chemistry. It is located where the pipes enter the heater. You remove it from the side of the manifold that is outside the heater. It is not a difficult job. Just make sure your pump does not come on while the heater manifold is open!
Apr 16, 2011 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
The red light is blinking 10 times. Fault code says...unexpected gas flow present. Shut the gas off and still blinks 10 times.
turn power off to re set code.I'm not familar with that code.they are usuall 1 to 6 blinks.are you looking at the list on cover to get this?is this heat pump with propane back up?is there a flame sensor? Does flame come on and then go out?not at all?
Jan 01, 2011 | Coleman Propane Forced Air Heater...
New Pool Heater not igniting on demand
if wired 120 volt make sure to check wiring red and black wires need to be changed ignitor not getting enough voltage
May 30, 2010 | Jandy ZODIAC LEGACY HEATER 400KBTU...
Tappan furnace blower will not shut off and furnace does not heat and red light is blinking one flash constantly.
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Mar 12, 2010 | Heating & Cooling
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
Laser 56 - leaking fuel at heater feed through
Sky,
It sounds like the igniter is no good. Everytime you try to start the stove the fuel pump puts fuel into the burner. If the igniter works it burns it out, if not it just builds up. If it gets high enough it comes out the igniter. Now, there could be another reason for the fuel. Have you ever pushed the little red putton on the sump? I will say, do not push that button until you know what it does. It can flood your heater big time. Rule of thumb for the red button, one time for one second, only.
You need to sop up the fuel from inside the burner. Use a rolled up paper towel. Once you have proved the igniter you can try again. If you can't prove the igniter you need a new one.
Tom Hawkins
hawkins111@gci.net
Jan 05, 2009 | Rinnai Toyostove Direct Vent Heater:...
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Pentair MASTER TEMP HEATER 400 000 BTU NG LOW NOX HD EXCHANGER Logo
165 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
