Question about Electrolux Heating & Cooling
The remote control is working, but it will not do anthing to the actual aircondintioner unit. Model No ESE24CRA
  • 3,530 Answers
If the control panel on the unit itself is working, do the following:
One way to check if the (IR) remote is working or not is by using a camcorder. The CCD in the camcorder can pick up lower frequency spectrum than what we can see (infra-red = lower then red frequency). So basically the camcorder can see the IR. If you push any buttons on the IR, you should see the IR source in your remote blinks when you look through your camcorder. If it does not blink, your remote may be dead. If light emits, it is either the receiver board or main board is defective.
Posted on Sep 27, 2010
I have a Marantz SR5000 receiver that stopped responding to the remote control. seems like the remote is working properly. The receiver also works fine besides the fact that it stopped responding to the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Aug 22, 2011 | Marantz SR-5000
I have a Bose Wave remote. Battery was replaced with the CR2032 and placed on plastic bracket and slide back into remote control. There appears to be no signal/power to Bose Wave unit. The battery is...
Remotes only allow you to avoid walking across the room to touch the unit for certain functions - like POWER. They don't actually enable or disable its ability to turn on if power is available. Walk over and touch the power control. If it turns on the remote is still malfunctioning.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Aug 04, 2011 | Bose Wave Radio
Does dimplex model 6902340100 have a fuse, stopped working no fan, no light took back panel off could not find a visable fuse.
My friend just had the same problem. It turned out to be the Remote Control box,( the little box you plug the Fireplace into so you can use the Remote). He just plugged the Fireplace straight into the wall outlet, (without the Remote) and now it works fine.
Oct 19, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
I have a rooftop dometic A/C With heat strip. Unit is controlled with a two button ceiling mounted selector control or a remote control. there are no selection controls on the adb box. Unit does not...
First thing I need to ask is , are you sure, it has the strip, or coil, and did it work before? Did you actually remove ceiling cover and see it in there? The reason I ask is that it is very common for someone to tell you it has it, but it actually has the option, but no coil installed, or lower control box is wrong one. Also, once that's confirmed, could you give me the model #'s off the base of the upper unit, as well as the numbers on the control box?
Obviously the cover inside will need to be removed to do all this.
Feb 07, 2010 | Dometic Rooftop RV Air Conditioner
Crime Stopper SP-500 problem
try this web site by crime stopper www.crimestopper.com or you can call their tech support at 800.98.6880 ext 210 you may have to program the remote again. you can also find that at the site by choosing support manuals then manuals again and finding the model number of the actual unit not the remote
Dec 06, 2009 | Combo Alarm and Remote Start with One For...
TOSHIBA MODEL 32A42 will not work with remote
so does't mean the sensors working do you get anthing on the middle lead ? Thats the one that sends the data to the uP.
Apr 14, 2009 | Toshiba Televison & Video
Garage door will not reprogram its remotes
Did you actually go to the power head and push the program button, then the remote button?
Is there a small wire hanging down from the power head? It's the antenna wire.
Jan 28, 2009 | Chamberlain 950CB Remote Control
REMOTE CONTROL DOESNT WORK
Some of the remotes that originally came with those units did not work or last very long. The manufacturer then later offered another remote to replace the first units. It looks like the model number you provided is a serial number, not the actual model number. I suggest that you contact Master Parts at 800-446-1446 with your model number (you should be able to find it directly on your unit with the serial number you provided) and they should have that replacement available for purchase. You also can find them on-line at www.masterparts.net. I hope this helps you!
Oct 18, 2008 | Vanguard International Blue Flame - Medium...
Remote problems
Replace batteries of your LG remote.
Oct 11, 2008 | LG 50PC5DC 50 in. Plasma HDTV
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
Heating & Cooling Logo
80 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
