Question about Canon PowerShot SD790 IS/ IXUS 90 IS Digital Camera
My shutter is not working properly, how to fix it? It has attached down and as soon as camera is opened it takes photgraph automatically.
    President:
  • 1,311 Answers
Apparently something is wedged in the shutter button, such as a piece of sand. With the camera turned off, hold it upside down while pressing the shutter button in all the way. Tap the body of the camera gently and see if this will dislodge the button. If this does not work, the camera will need to be disassembled by a camera technician.
Posted on Oct 13, 2010
Why does my Shutter locks when taking picture
Sir,
This is a common fault in such models. carefully open the back cover and bottom of your camera thus you can find the shutter opening gears and related parts. with the help of a needle apply some silicon grease on this gears let it free by rotating the parts then fix the covers it will work properly, check the condition of the battery in some cases weakness of the battery also cause this
thanks raufkdv@hotmail.com
Sep 05, 2014 | Sony A Alpha - Camera Digital Slt-a65v Slr...
My pentax w90 will only take a photo automatically when turned on,
Per Evan89's remark above, on these units the "shutter" button fails in the "on" or "down" position. There are a lot of reports on the internet. As soon as you turn the camera on it charges the flash and takes one or more pictures. It won't respond to other controls because it senses that the shutter bitton is depressed. A side effect is that the battery drains quickly.
I'm looking around to see if I can order a replacement switch assembly since these cameras are easy to take apart.
Dec 24, 2011 | Pentax Optio W90 Digital Camera
My samsung BL103 camera takes good pics inside but ot outside. how do i fix
First make sure that you are in "Automatic" mode, and not in one of the camera's othe manual modes which may keep the shutter open for an extended period. But if you are indeed in auto mode, and it's still doing this, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 09, 2011 | Samsung BL103 Digital Camera
Stopped focusing properly. Now get only black when looking through view finder or on screen. other features seem to be working correctly
A stuck shutter is a common failure mode for some model digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 13, 2009 | Canon PowerShot S2 IS Digital Camera
Blackness ... everywhere
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 10, 2009 | Canon PowerShot S2 IS Digital Camera
How to fix canon ixus 7o lens error restart camera?
Do you mean its taking black pictures? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 05, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
M42 adaptor
Quite right too. When the M42 adaptor is fitted there is absolutely no exchange of information between the lens and the body: M42 lenses pre-date all of those later developments. Your camera will also be unable to stop down the lens automatically when taking the picture, most M42 lenses don't even stop down automatically when connected to an M42 body.
You need to do things the old-fashioned way. Your camera needs to be set to meter manually, shutter priority mode may also be used. In manual mode you focus the lens as normal with the aperture ring set to the lowest aperture number (i.e.aperture is wide open).
You then make sure that the lens in in manual mode as well and stop down to whatever you want, if the image remains bright enough then you can adjust the precise focus using the hyperfocal principle if you like which takes advantage of the increased depth of field of a stopped down lens.
In manual mode, you then tell the camera what aperture you have set (read it from the lens barrel) and set the shutter speed using the camera's light meter to guide you. If using shutter priority mode then the camera will choose the shutter speed for you.
Check everything is set as you intend and press the shutter.
It all sounds long winded but is exactly how many of the world's greatest photos were taken and soon becomes second nature. You also learn far more about the relationship between aperture, shutter speed and ISO settings and will be able to talk about reciprocity like you know about it!
Jun 26, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
My screen is black or blank
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Feb 23, 2009 | Nikon COOLPIX L18 Digital Camera
Hp m417 shutter problem.
I had the same problem but it cleared up after a phew weeks on its own awkwardly, but the only advice i can give you is to open it yourself before you start taking pictures.
Dec 08, 2007 | HP Photosmart M415 Digital Camera
Canon PowerShot SD790 IS/ IXUS 90 IS Digital Camera Logo
150 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
