Question about Dell E173FPb 17" TFT LCD Monitor
I need help
I have a compaq pc and i just baught a dell flat screen monitor from my friend and when i hook it up it says cant display this video mode.. Any ideas Thanks
Make sure you have the correct drivers installed by going to device manager in control panel..... if you have then you'll need a better graphics card as yours is prob onboard using system memory with a limited output in resolution
Posted on May 23, 2008
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
My Brother is trying to connect to HP Pavillion XT914. A friend connected her flat screen to his pavillion to help him delete unwanted files and he can't get the monitor to work any more. How do we get his...
It might be that the screen resolution set on the pc is too high for the monitor to display.
try hooking up the flat panel monitor again. (CRTs can have a flat screen as well)
lower the screen resolution to 1024 X 768 pixels click save.
hook up the other monitor to see if that was the problem.
If you can get the monitors menu to come up on the monitor try setting it to factory defaults.
If no luck, does the monitor work on another PC?
Let me know if this helps you or not.
Thank you
Feb 05, 2011 | HP Compaq FS7600 17" CRT Monitor
Hi, I have a dell dimension e521 I hook up a old monitor to it and, it work but whei i hook up a new flat screen monitor it said (can not display video
Are you using the same VGA cable. Try to use the same VGA cable which is there is in Old Monitor
Though it can be issue with the resolution setting also of the Video
For that when you plug in your desktop to old monitor bring the Resolution to the minimum and then Connect it to your New Monitor
Jan 06, 2011 | Dell Dimension E521 PC Desktop
Change from a monitor to a flatscreen
You need hook up your old monitor back and set the PC video resolution to 1024 × 768 @ 60Hz which is the native/max resolution of the E15T4, remove the old Dell monitor and connect your E15T4.
You are getting out of range because your PC video resolution is too high for the E15T4 to display.
Apr 28, 2010 | E-Machines eMachines Monitor E15T4
I just want basic hook up from my hp compaq to dell flat screen
Most Monitors use the 15 pin cable that is compatiable with almost any computer. I would check the back of your computer for the blue monitor port and then check the cable on the monitor to see how many pins there is.
Feb 23, 2010 | HP Compaq dc5750 Microtower - Free Flat...
I have a Compaq Presario laptop with a broken
Hi:
Just plugging in the monitor to your VGA port on the laptop won't make it display. You have to toggle to the exteral display, or both. Usually you have to hold down your function key, and then hit the external display key. It could be F1 thru F8, depending on your laptop model. Mine is F6. If you toggle thru the modes, your CRT should display . The missing pin is no concern!
Dec 11, 2009 | HP Compaq Presario F761US Notebook
Hooking up the monitor
She should not have a prioblem. The PC should recognize new devise and look for the driver. If it says that driver not found, Go to DriverGuide, this is a great website and you can download any driver for FREE. Install it then she should have noprobs.
Jun 15, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
Hook up monitor speakers to PC?
how i hook up my JBL SPEAKER TO MY COMPAQ COMPUTER LOST MY DIAGRAM TO THE COMPUTER FORGOT HOW TO HOOK THE WIRE TO MY COMPUTER
Mar 18, 2009 | Compaq fs740 17" CRT Monitor
I am trying to hook my 40 inch flat screen by samsung to my dell computer. i unplugged the cpu monitor and plugged it to my tv and the tv states that the mode is unsupported. What do i do?
Your computer is set to a resolution supported by your dell monitor but not the flat screen tv.
The easiest way to get it working is to turn the computer off, connect the flat panel to the computer and then turn the computer on.
To change the resolution of the flat-panel or monitor, right-click on the desktop, click on properties and then select the settings tab.
play with the screen resolution and find one that works best by trying each one and clicking apply. If you select a resolution not supported by your flat panel, computer will automatically revert to the previous resolution in 15 secs.
Feb 26, 2008 | Televison & Video
Dell E173FPb 17" TFT LCD Monitor Logo
70 people viewed this question
Alun Cox
