Question about Refrigerators
Hi, I had purchaed a Samsung double door fridge model RT77KBTS 570 Ltrs on 06 Aug 2010. The fridge was delivered to me with a dent on the lower door and I had mentioned this in the delivery chalaan. When the service engineer visited me on 09 Aug, he inspected the fridge and endorsed a similar remark in the inspection form and promised that the door will be replaced. Since 09 Aug 2010, I have lodged repeated complaints (on 17 Aug; 06 Sept; 17 Sept; 27 Sept) but no one seems to be bothered in addressing the complaint number 8404128796. I am deelpy disappointed and astonished at the Samsung Service Center response. Is there somebody who can address this issue on priority or is that the promise of service and customer satisfaction by Samsung is just lip service? Hoping to hear from someone. Regards Col M Sehgal NOIDA, India
SOURCE: Poor after sales service from Sansui
I am in th same boat. I tried to extract some useful contact info
from their global website, http://www.sansui-global.com. There
you will find the "World wide Distribution Network" link. Apparently, Sansui is represented by Vidoecon in India, and the products are manufactured in the Videocon plant in noida (?).
The BIG Problem is that Videocon represents 18 popular
brands (except a few like Sony, Sharp etc..) and enjoys 80%
of the TV market. They are the monopoly. PASS THIS WORD TO EVERYONE WHO WANTS TO BUY A NEW TV OR ANY OTHER CONSUMER EQUIPMENT
THEY ARE THE former DOT(currently BSNL) in present day India. A BIG MONOPOLY.
The page gives out the contact for distributor as
Videocon Industries Limited,
C-6 Ashok Steel compound,
CST Road,
Santacruz East Mumbai 400098, India
(91) 22 - 2652 8826
(91) 22 - 2652 6768
Try calling them, or write an email or speak to
anilkhera@sansuimail.com
See what happens. Pls. remember to keep the telephone bill,
email copy and approach the consumer court with evidences.
Pursue TV channel to air all there as a documentary. You are not afraid of TV cameras, are you ?
Good luck
Posted on May 26, 2008
SOURCE: Blinking temperature control
hi
this refrigerator having problem related with defrost cycle.fridge is able to defrost after period.please check it as follows
there is timer box located behind the fridge near to compressor with white color knob.attach the clamp meter on one wire of main cord,check current drawn by fridge when comp.is running.turn the timer knob clockwise to hear big tick sound where the comp.will stop,check the current in meter which should be 0.6amp.if it is not showing then there is problem with bimetal or heater which is inside the frizer
Posted on Jun 01, 2008
  • 62 Answers
SOURCE: Interior Lights "ON" With Doors Closed
If you have a Sears model with the model number beginning with 795 the unit was built bt LG. You can check with LG. However, if you have the problem with the interior light staying on, LG and Sears will honor that problem as a warranty call going back 3 years. No cost to you. call Sears and arrange the call.
Posted on Aug 30, 2008
projdoc
  • 2237 Answers
SOURCE: Cooling system of my LG frostfree refrigerator is
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 26, 2009
SOURCE: Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Posted on Jan 03, 2010
I have Samsung 230 ltr double door refrigerator with model number RT24BDTS1/XTL/2010.
The thermostat is defective and needs to be replaced with a new one.
Jul 24, 2015 | Samsung Refrigerators
We have a Samsung side by side fridge model number SRS 596NP. It is a double door (side by side) fridge/freezer. After moving house the top right hand door does not seal properly and is slightly lower than...
  1. Anytime you move a fridge there is a chance that the doors will slide of balance so to speak, the simple fix is usually to readjust them by tightening/loosening the screws on the mount at the top of the door(usually under a cap that is the same color as your fridge). You want the door open when you adjust the level of the door and depending on your model the bottom may need to be adjusted as well. It should be pretty simple just open the door and hold it up a bit to about where you want it to sit and tighten your screws on the hinge, hopefully that helps.
Dec 04, 2013 | Samsung RS2630SH Side by Side Refrigerator
We just bought this fridge from home depot. We got it at a good price because it has dents. They delivered it today. They left no directions or any type of warranty. We have an ice maker in it. We have no...
Ok
give it 24 hours to balance itself . It has 2 evaporators.Make sure you hear fans in both compartments.This machine is highly computerized . If it is not giving you any trouble codes ,all systems are go.
Re post problem if not normal in 24
Sep 06, 2011 | Samsung RF265AA Bottom Freezer French Door...
Our samsung fridge front panel is dented. Is it possible to replace the panel?
If you check with searpartsdirect.com, they have the door assembly for $120 plus shipping and tax. To remove you would need to take the top hinge bracket off to remove the top door then the middle hinge can be remove to allow you to replace the lower door. Hope this helps you.
May 06, 2011 | Samsung RB1955 Bottom Freezer Refrigerator
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 14, 2010 | Samsung Refrigerators
Model#25360722000 is this a freezer or fridge? kenmore
What is it? A single door or a double door unit. If a single door, what temperature does it go down to? lower than 0 deg. c or +/- 3 to 5 deg. c In other words, lower than o it is a freezer. Above 1, it is a fridge..
Jun 03, 2010 | Kenmore Freezers
Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
