Question about Meade Telescope - Telestar DS-2130AT Telescope
Telescope handset is not communicating with the scope unit. it is not the batteries, it is like the mother board has crashed, it worked fine for the first week then stopped. crappy thing is that we bought it from a garage sale so there is not warranty. do we need to buy a new handset or is there something that we can do to get the current one to work. thanx for your time. korie
  • 3,186 Answers
No, only Meade sells a replacement hand controller.... but if you burned out the internal board it is not worth fixing. Here is Meade's customer service phone number:
http://www.meade.com/support/index.html
Posted on Sep 27, 2010
Testimonial: "honest answer even though it wasn't the answer i wanted!"
I have a Meade ETX-70. When turned on, the handset says there is a Motor Unit Fault: Motor failure detected due to moving handset between scopes, low battery level, obstructed or overloaded scope. I've...
This is usually caused by low battery power-- as the hand controller reported. DO NOT USE rechargeable batteries they do not have enough volts. Use alkaline batteries only.
This can also be caused by a broken gear or a failed internal motor. You can return these to Meade for repair.
Here is the contact number:
Sep 14, 2011 | Meade ETX-70 (240 x 70mm) Telescope
I purchased the telescope a week ago and it want power on when i put the batterys in it
If this is a new scope return it.
If you bought it used it is already broken.
Only a few things you can try-- borrow another hand controller and see if that works. and replace the hand controller cable. Beyond that the scope will need to be dis-assembled and probably a circuit board repaired.
Meade will repair the scope but you will need to send it to them.
Mar 16, 2011 | Meade DS-2114 ATS (325 x 114mm) Telescope
Red wire from battery off, where does it go?
It broke off of the circuit board. Actually I PURPOSELY cut both of the battery wires OFF! This makes it much easier to work on the internal gears.
Just buy a separate 12 volt power pack and stop using the internal batteries. The scope functions better on a regulated separate power pack. Buy the proper 12 volt cigarette lighter style power cord.
I never use the internal batteries and have removed them completely from the scope. If they leak they will ruin the circuits inside the base of the scope.
Nov 28, 2010 | Meade ETX-90EC (325 x 90mm) Telescope
I have a meade lx200gps 10" scope. The ra up is not responing. the down is working only. After initializing and fining north the auto star says stalled motor.
Do a calibrate motors and make sure you are using a separate 12 volt power pack or BRAND NEW internal batteries. All goto scopes work better with smooth, regulated power. The internal batteries will NOT work well for very long.
The Calibrate motors routine adjusts the motors for the power supply being used.
Oct 10, 2010 | Meade LX200GPS Telescope
I have an older Meade LX200 GPS with autostar II handset. The telescope was working fine and last night I got an error message on the handset "Error: Inv. Heap" and the telescope locks up with no further...
You may have Corrupted firmware in the hand controller- that's why they want you to do a RESET.
You might have to reload the correct firmware to fix this problem.
I believe if you hold down the ENTER KEY and the SCROLL DOWN arrow key and then turn on the scope you enter SAFE LOAD where you can reload the firmware.
Sep 02, 2010 | Meade Optics
Display on the autostar does not light up. The batteries are all changed, the power light comes on on the tripod, but the handset is dead.
Could be a cable problem. REVERSE the cable ends and try it again. Make sure the scope is always turned OFF before you plug or unplug a cable.
If this does not work then try a new cable. Meade sells these, or you can order a nice one from www.scopestuff.com . Not very expensive.
If after installing a NEW cable it still does not light up then time to buy another hand controller.
http://scopestuff.com/
Oct 31, 2009 | Meade 494 AutoStar Telescope Control Unit...
ETX-125 Autostar controller not working
I assume the small red light on the power panel is ON. ???
If it is the scope is receiving power--- check to make sure the cable from the hand controller is plugged in properly-- jiggle the cable to see if you have a loose BAD cable. Before you panic --- try another cable or reverse the ends ---
Before you buy another hand controller try a new cable-- scopestuff.com sells a nice long flexible one for the 497 hand controller.
Jan 14, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Missing finder scope
i actually have the star finder and its **** honestly. but well mine is old to. so a new one might do you better. but i've attached a rifle scope to mine.
Aug 04, 2008 | Tasco Astronomical 302675 Telescope
Computer control and pointing with NorthStar Goto & Autostar
Your reseller is correct. The wire (Meade cable #505) goes from an RS232 serial port on PC to a 4pin RJ plug. This plugs into the 2nd socket on the bottom of an Autostar 497 handset, the other socket being used for the curly lead to the telescope. So it goes PC to Autostar to telescope.
A common error is to try plugging the serial wire into an "AUX" ort on the telescope control panel - same connector. Not only does this not work, it can cause a lot of damage.
Wired like this you can control the scope from Meade's Autostar Suite (or many other planetarium softwares). You can also update the Autostar software to the latest 2009 version.
What else can go wrong? Well, many people want to control from a laptop, and modern ones don't have RS232 serial ports. Then you need a USB-to-serial convertor dongle, which effectively add a serial port to a laptop. But they often give it a very high port number (eg COM17) that the planetarium software does not find. Use Control Panel to reset the USB-serial-port to COM 1, 2, 3 or 4 and all should be well. But it can be a right fiddle!
Apr 01, 2008 | Bushnell NorthStar Goto 100mm 788840...
Optics Logo
176 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Are you a Meade Optic Expert? Answer questions, earn points and help others
