Question about Ace Hardware Power Glide Circular Saw with Laser
Can't tighten circular saw blade, actually when it tight the blade is blocked and if I loosen it, is too loose.
  • 699 Answers
You need to use the correct (reduction) ring adapter for the cicular blade you intend to use: the adapter 'washer' needs to be the exact size for the middle blade hole and the motor shaft. If ensure, as it is a lethal tool, ask your friendly hardware shop handyman for advise and direction.
Hope it helps.
Posted on Sep 27, 2010
Witch way to turn the blade bolt on a 10" table saw
I'd be surprised if it were anything but a normal, right handed thread.
So, put on some leather gloves, block the blade from turning with a piece of scrap lumber. Use the appropriate size blade wrench and, I assume you're removing the blade, pull the wrench toward you to loosen it. Always remember, lefty loosy, righty tighty and you'll never wonder which way to turn it again. Obviously if this method tightens the nut rather than loosening it, it's a left handed thread and needs to go the opposite direction. Should loosen/tighten rather easily, so don't force it one way or the other.
Aug 31, 2014 | Skil 10" 60T Skilsaw Circular Saw Blade -...
Which way does the nut turn to loosen blade on a luds mitre saw
On any saw blade, you will loosen the nut (or bolt) in the direction that the teeth of the blade are pointed. This is because any saw must be designed so that the force of the material being cut pushes against the blade in the direction that would tighten the blade. So, on a miter saw with the blade on the right, when viewing the blade from the right the teeth are pointing counter-clockwise (or left), so you loosen to the left. On the other hand, a radial arm saw or a circular saw where the blade turns clockwise, loosening will be to the right. Good luck.
Jan 13, 2013 | Saws
Circular saw motor turns when tightening saw blade
Insert a tool such as a screwdriver across the blade guard and against a tooth to prevent blade rotation, then tighten the blade nut. Be sure to remove the wedging device before operating the saw
Dec 29, 2012 | Now Evolution #Fury 7 1/4" Mp Circular Saw
To remove the circular saw, which way do you turn the nut hold the blade on the saw?
For any saw blade or grinding wheel, the rule is this. Pushing against the points of the teeth should be the direction that tightens the nut. So you must loosen it in the same direction that the blade spins. For example, if your saw blade is on the right side of your saw, then the blade spins counterclockwise, and the wood pushes against blade clockwise - so you turn it counterclockwise to loosen it (which is in the same direction that the blade spins.). If the blade is on the left side of the saw, you loosen it clockwise. Good luck, Al K
May 22, 2011 | Sears Craftsman Circular Saw Blade
Cannot tighten blade on old craftsman circular saw.bolt turns blade shaft and motor without tighting blade
Is the washer/spacer in the blade too thick and you are perhaps tightening up on that instead of the blade. Also check the threads on the bolt, see if the bolt turns all the way in without the blade in position. It may be jamming up before gripping the blade.
Jan 24, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
Recalibrating the angles
look on top of fence
see 4 holes
loosen 4 bolts (probably hex wrench) and fence will loosen also
framing square against loose fence and lowered blade (to calibrate square)
tighten fence,... square to blade
Jan 15, 2011 | Makita 10" Dual Slide Compound Miter Saw...
I cannot loosen the bolt that holds the blade on my 7 1/4 Makita circular saw. How do I make the blade stop spinning to loosen it?
they make a blade holder now but usually if you hold the blade against a wood block real tight you can loosen the bold / screw . most warn against over tightening them
Sep 04, 2010 | Makita 18V LXT Circular Saw
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
Ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Sep 28, 2009 | Ryobi P501 18v Circular Saw Only
Where is the blade lock button on a skilsaw 5150 2 1/8hp ???? i can't get the blade off and turning the saw bolt the same direction as it spins isn't working.
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Jun 25, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Ace Hardware Power Glide Circular Saw with Laser  Logo
376 people viewed this question
Top Ace Hardware Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ace Hardware Saw Expert? Answer questions, earn points and help others
