Question about SanDisk Sansa e200 MP3 Player
Screen is messed up won't turn off
The screen won't turn off and it shows a light blue backround with verticle blue lines running down the screen
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
For about 6 months there has been a faint gray/black verticle line running down the middle of the screen . is worse on blue/green backgrounds, and is almost not noticable on white backgrounds. I know that...
I've seen a similar looking problem and it is a bad LCD panel. It will show even on a non-used input, and will show through the menu screen and the screen saver, also. Sharp's LCD panels are very expensive,too. Over 4000 at encompassparts.
May 03, 2010 | Sharp AQUOS LC-45D40U 45 in. LCD...
Verticle line running down the screen.Thin verticle line running down the screen.
You have a defective LCD panel. The only way to fix it is to replace the whole LCD panel. It is the most expensive part in the TV (usually $500-2500) depending the make, model, and size. It is also time consuming as you need to take the whole TV apart in order to replace that part.
Oct 09, 2009 | LG Televison & Video
Have an hp pavillion a6319fh boots to blue screen and curser
Could be alot of things, Scratched , even a small pinprick on the CD, or you have some bad ram, or your Hard drive is going. Thats the thing about troubleshooting a PC.
Sep 22, 2009 | Computers & Internet
No Picture on a Hitachi 42EDT41A
Then it is probably not cold solder joints. You wouldn't think that an lcd TV would need a high voltage transformer but it does. They are very small compared to CRT televisions but they power up the screen. Without it you have no backround light to veiw what is there. There are two neon lamps on either side of the screen but they rarley go bad. My guess is the transformer ot the power supply feeding it.
Jul 25, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Screen on my extensa 5630 laptop shows nothing but verticle lines
I had to finally send the machine to ACER and it was a hardware problem; they have to change the cable linking the display with the MB
Mar 22, 2009 | Acer Extensa 5630-6806 Notebook
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
SanDisk Sansa e200 MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
