Question about Excelstor Technology J880 Hard Drive
How to format excelstor hardisk? - Excelstor Technology J880 Hard Drive
  • 699 Answers
For your specific operating system, assuming that Windows is running, locate Admistrative Tools -> Disk management.
You should see Disk 0 or Disk 1 with your Excelstor 80GB drive: if you do not have a partition, create one or more partition, assign drive letter(s) and then format using the context menu.
If you do not see the drive in the Disk Management screen, then your Bios has not been setup properly or your drive is not connected properly.
Hope it helps.
Posted on Sep 27, 2010
    Master:
  • 633 Answers
Try formatting it using command promt.
U can use the command given below
format /q
Eg: format /q e:
I tried connecting my iomega prestige hardisk to my ps3(I just bought) but it is showing no icon or any notification of my hardisk being connected.What should I do to view its contents on ps3? about my...
You need to format your drive as FAT32.
If you are using Windows Vista or 7, you will have to google search for a FAT23 formatting tool. So take your data off the drive. Format the drive, put your files back on the drive and your good to go.
*************CAUTION************
There is a 4GB per file size limitation with FAT32!
Dec 14, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Oct 03, 2010 | Computers & Internet
Did not see second sata harddisk
To know if your Hardisk is detected follow this steps:
In Windows XP
1. Open Control Panel
2. Go to Administrative Tools
3. Open Computer Management
4. Double Click Storage
5. Open Disk Management
All the list of Hardisk is here, your hardisk is not formatted that's why, so you have to proceed to format just right click that unformatted hardisk and choose format, specify the label for your hardisk or simply leave it blank.
Jan 11, 2010 | HP dc7600 Small Form Factor P4 640...
Sata hard drive not recognized by windows
If it is a new drive, then you need to partition and format it for windows to see it. To do this, click START, RUN and type in compmgmt.msc. CLick on Disk Managment. Look for the new drive, right click on it and select partition. When that is finish, right click the drive again and select format. Format the drive as NTSF..
Mar 31, 2009 | ASUS P5LD2-VM Motherboard
My computer freez and go blank after formatting the computer
Greetings,
There is no problem with your computer as a whole it is your hardisk that has a problem, It cannot continue installing the system files because an error occur in your hardisk. Format your hardisk with other computer.
If you have an extra hardisk much better.
Thanks
Nov 12, 2008 | IBM NetVista PC Desktop
Excelstor j8160 hdd
right click on the 'My Computer' icon, go to 'Manage', then click on 'Disk Management', and see if you need to either format the drive, assign a drive letter, or if it's recognized correctly. Most of the time, you'll find the drive in here just needs to be formatted, or it needs to be assigned a specific drive letter.
Aug 19, 2008 | Excelstor Technology J840 Hard Drive
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Can't See HDD in Windows Explorer
Afraid Excelstors hard drive repair tool requires the drive to get wiped to fix the errors not like seagate or western digitals, only thing worth trying is put in a windows xp disc and boot off the disc, Press R on the first screen to do a repair in like dos mode. it will take you into a black screen with a dos prompt, type this in CHKDSK C: /R then press enter it will take about 30min-1hr but has a good chance of getting the drive to read.. once complete take out xp disc and restart pc all the best John
Sep 18, 2006 | Excelstor Technology J840 Hard Drive
Excelstor Technology J880 Hard Drive Logo
479 people viewed this question
Top Excelstor Technology Computers & Internet Experts
Elise Lacoursiere
Elise Lacoursiere
John Anderson
John Anderson
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an Excelstor Technology Computer and Internet Expert? Answer questions, earn points and help others
