Question about Fuji FinePix A201 Digital Camera
Protected card - Fuji FinePix A201 Digital Camera
  • Fuji Master
  • 17,130 Answers
The card has a small swich on the side section which when pushed locks the data from being erased off accidentely.
so move it and the protect will change and allow the card to be written once again.
Posted on Sep 27, 2010
    Genius:
  • 1,340 Answers
Is it a new card?They usually come in the locked position.Remove the card.There should be a metal tab on it which slides and has a limit on both ends.Slide it to the other end,put it back in the camera.If this does not help,please reply here and I will get an autolink to your post and will reply ASAP.Good luck! Greg
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How can i format write protected micro sd card 32gb....
Slide the write protect tab forward to remove the write protection. You cannot format it while it is write protected. Formatting will erase all data on the card. Install the card into a Windows or MAC and wait for the device to detect and mount the card. Use the appropriate procedure for the machine to format the card. See this procedure for additional step-by-step operations after the write protect tab has been moved.
How to Format an SD Card
Oct 22, 2015 | Electronics - Others
The camera card is now write protected. How do I remove this?
You didn't say what type of card so I'll assume it's an SD card.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 15, 2014 | Office Equipment & Supplies
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
Want to copy some files to a memory card from a laptop but it says that the memory card is write-protected. how do i remove the write-protection to copy the files.
Some memory cards are having a write protection switch integrated on the side or on the back of the memory card for preventing the content from being erased or overwritten by accident, just like floppy disks. Both SD Memory Card and xD-Picture Card have their write protection switch on the side of the memory card in contrast to the Memory Stick PRO and some Memory Stick Duo that have their switch on the back of the card.
The SmartMedia Card is also supporting write protection but not with a switch. For protecting the SmartMedia Card's content you need to put a sticker on the card's write protection pad. It is the circle that can be found in the middle of the card, when facing the front of the card.
Oct 24, 2010 | Computers & Internet
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
"card protected"
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Mar 09, 2010 | Vivitar ViviCam 8025 Digital Camera
Remove write protection from micro-sd card
  1. Remove the Sandisk SD card from your portable electronic device. Ensure that the SD card can be safely ejected before removing.
  2. Locate the write protect lock. The write protect lock should be on the side opposite the cut-off corner of the SD Card.
  3. Disengage the write protect lock. To do this, gently slide the small switch upward, toward the top of the SD Card. The card should now have write protection disabled.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Mar 03, 2010 | SanDisk 2GB microSD Memory Card
Write protection problem of my mobile memory card
Hi..
To remove the right protection it is very simple, first remove your SD card in your mobile, the observe your SD card back to back, if you can see a small button you need to slide that button to remove right protection, then plug your SD card back to your china mobile and try to copay a folder,
Good luck !!!
Regards
PCmania
Jul 11, 2009 | Nokia N72 Cellular Phone
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
Fuji FinePix A201 Digital Camera Logo
69 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
