Question about Dryers
My fridgidaire crown gas dryer will not heat up. i took off the back access panel, and can see it light up for a few seconds and then go back out. it will then continue to do that, but will not heat up.
  • 205 Answers
Hello- It sounds like the gas coils are bad and not holding the valve open. It's a pretty common issue. The parts are pretty cheap but you should have someone out to change them for you. Hope this helps, best regards.
Posted on Sep 27, 2010
My frigidare heavy duty crown series gas dryer is n0t heating and barely able to dry my clothes--what could be the problem and how can i fix it
Hello Chuck, thanks for your inquiry
Based off the information you have provided I have identified a few possibilities as to why your dryer is not heating could be the element, thermostat, or control panel. Each component controls the heat within your dryer and if one goes out it is possible that can cause the rest to not function properly. To accurately find out the reason to why your dryer is not heating I would recommend having a professional come out. Hopefully this is helpful. -Matt
Sep 28, 2014 | Frigidaire Dryers
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
The dryer does not dry. No heat. I took off the bottom plate and turned on the dry. An electrical element turned a bright orange for a few seconds and then darkened. No gas went on.
Because you have a gas dryer, your problem is probably caused by the ingition panel, the electrical element that you saw turn a bright orange. Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat.his is what you described when you said the element only lit for a few seconds. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 24, 2011 | Dryers
Sg7800 maytag dryer stopped giving heat
Sounds like burner not igniting. On front of dryer in the lower right there should be a gas valve/burner access panel. Usually you just have to pry out at bottom of panel & swing out and up to remove. This gives you access to valve coils and igniter. With panel removed set timer for heated dry and start dryer, observing first the igniter which should glow bright orange-red, then after a couple seconds you should hear a "Click" which is gas valve opening and a blue flame ignites for heat. If no glow is seen after a few seconds or at least a minute, igniter is bad, if it does glow and no click is heard from the gas valve, the coils (electro magnets) on the valve are bad, or the "Flame present" sensor is bad. Chances are it's either the coils or igniter.Try this on all heat settings, if you get heat at only one setting it might be in timer contacts, but not common. Again you can repair/replace both the igniter (usually just plugs into a receptical) and the coils (2 donut looking objects on the gas valve, replace both.) Access door may be on back if not on front, but normally their on lower right of front.
Feb 13, 2011 | Dryers
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 09, 2010 | Dryers
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
No heat
If your dryer has an access panel at the bottom front remove it.  Start the dryer in a cycle and watch the burner area. You should see the ignitor start to glow. After a few seconds of it glowing you should hear a click and the gas come on and ignite. If the ignitor does not glow, look on the top of the air duct to the left of the gas valve. You will see 2 temp sensors. One will be white with  2 small blue wires going to it.    UNPLUG THE DRYER NOW    Remove the wires and connect them together.   BE SURE THEY DO NOT TOUCH ANYTHING ELSE
Plug dryer back in and start dryer again and see if ignitor glows and burner lights. If it works now, you need a new thermal fuse. You also want to make sure the vent duct is not clogged with lint or the hose is not kinked.  I DO NOT recommend that you run the dryer with this bypassed. It is a safety mechanism.
If this is not the problem or your dryer is not front servicable, post back and i will try to walk you through the problem.
Oct 11, 2007 | Dryers
Dryers Logo
Top Dryers Experts
