How to install usb camera? - Computers & Internet
  • 699 Answers
You need to install the USB camera driver that came with it on a CD or mini-CD: plug the USB camera and if the camera driver is not a 'standard' type, it should prompt you for the driver location (which should be the drive assigned to your CD/DVD device).
Hope it helps.
Posted on Sep 27, 2010
MTP USB device failed to install on Windows 7
Did you instal the software that came with your camera?
You also can download the new View NX from Nikon for free. Always first install the software, before connecting any device on your computer. Special what it is a device like a camera.
The computer can interpret a camera on an USB for: Now I nave to charge the battery. Or when you start the program to transfer pictures, now I have to download pictures, or some camera's like your D200, also cam be controlled remotely over the USB, if the correct software for that is installed.
The software windows needs to install has to be on the computer first.
May 15, 2013 | Nikon D200 Digital Camera
The memory card is not showing my pictures when i plug my camera into my laptop
Please follow the steps below for connecting the Camera to the Computer for transferring the images.
Turn the Camera ON.
Turn the Computer ON.
Make sure to Insert the Memory Stick in the Camera.
Set the USB CONNECT option in the Setup 2 Menu of the Camera to PTP. [Set the Mode dial of the Camera to Camera, press the Menu button, select SETUP-->SETUP2-->USB CONNECT-->PTP-->OK.]
Connect the Camera to the Computer using the supplied USB cable.
The Computer will automatically install the USB Driver for the Camera.
When the installation completes, an AutoPlay window will appear.
In the AutoPlay window, click the Import Pictures option.
In the Importing Pictures and Videos window, click the Import button.
If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat changing the USB CONNECT option to PictBridge, Mass Storage or Auto.
If the issue persists, try connecting to a different USB port on the Computer.
Try re-installing the USB Driver from the Device Manager.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Labtec webcam not working why i did every thing my computer not detecting this ****** i install all the posible drivers already i used window xp. I hate this man.
ok, uninstall all related drivers to this camera,
Now using the supplied disk install the camera software but please do not connect the camera YET, if the camera is already connected,
remove the camera and reboot,
so you installed the camera software now plug the usb camera in, it will now detect the install camera software and work.
Regards
gewiz.
Dec 05, 2009 | Labtec 961307-0914 Webcam
See me web cam not installing on computer
Did you have the camera plugged into the USB port when you installed the soft ware? If you did it does't install properly. Disconnect the camera from the USB port and re-install the software and when it asks you to connect the camera to the USB port, do so and finish the install. The camera should operat properly then. Worth a try as this has been the problem with most of the cameras I have dealt with. Good Luck, Bud
Jan 03, 2009 | Logitech Webcam
Problem Installing ZSMC USB PC Camera (ZS211)
I am trying to install ZSMC USB PC Camera (ZS211). When I tried
installing it in my Laptop (COMPAQ Presario V4000), i get message
Cannot Install this HArdware. There was a Probelm Installing this
hardware.
Aug 19, 2008 | Cameras
What should I do if my PC still won't recognize the camera after I reinstalled the USB drivers?
If the camera is still not recognized after the USB driver has been re-installed, one of the following situations may apply. "PC Camera" may be selected as the USB setting on the digital camera. Change the USB setting to DSC or select DSC in USB MODE. (This only applies to models with a USB Setting or USB MODE option in the SETUP screen.) Does the LCD monitor on the digital camera show that the USB connection is active (USB, DSC or a USB symbol with an arrow, etc.)? If not, the digital camera and PC may not be connected correctly. Check the items listed below. a) Restart the PC and reconnect the USB cable. b) If the PC has multiple USB ports, connect the cable to a different USB port. If steps a) and b) have both been tried and there is still no USB connection indicator displayed on the LCD monitor, there may be a problem with the digital camera or USB cable. Contact an authorized Fujifilm service center and ask them to check the digital camera together with the USB cable. Refer to the Digital Equipment Repair page for information such as the procedure for requesting checks and the locations of authorized Fujifilm service outlets. The USB driver may not be installed correctly. Download the USB driver from the Digital Camera Downloads page and re-install the driver The camera may not be recognized correctly if it is connected to an added USB interface board or via a USB hub. Always connect the camera directly to the USB port on the PC.
Aug 30, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
