Question about Kenmore 16812 Washer
Washer pumps, but dosent spin, already bypassed lid switch? it will spin if turned off, then back on?
  • 205 Answers
Hello- Sounds like the timer is not pausing before the spin which it should do. Could be the timer or the clutch. Is every cycle the same? You may have to just sit and watch it without advancing the timer manually and see if every cycle is the same, if it is, it's less likely the timer. Good luck.
Posted on Sep 27, 2010
Washer agitates but won't spin or drain - makes a humming/buzzing sound during those cycles
check the pump,could have a sock or something stuck in it.usually i would say to check the lid switch,open and close the lid,if you don't hear a clicking sound the washer won't go into spin or drain but if you're hearing a humming sound that's the motor watch this video
http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw it will show you how to get to the pump.pop off the two clips that hold the pump on and remove the pump just pull it backwards off of the motor shaft,now get a piece of wire and strip the ends on it,2 to 3 inches long,unplug the washer before you start to work on it,get your jumper wire and stick it into the wire harness that connects to the lid switch, don't plug it into the ground plug it into the other two wires not the green wire,i'm pretty sure it's the two outside wires and the green ground is in the middle,plug the washer back in and pull the timer out in the spin cycle,if the motor runs and spins you know something is stuck in the pump or the pump is bad,but just to make sure it's not the lid switch and it is the pump put the pump back on and start the washer again if you hear the humming it's the pump or before you pull the pump jump out the lid switch and see if it spins and drains,if it doesn't then pull the pump so you don't have to stick the bad pump back on the washer,all the lid switch is for is so the washer will not run in the spin with the lid open and some washers won't even agitate if the lid is open by using the jumper wire we are bypassing the lid switch to check the washer while it's apart.hope this helps and if you can let us know how you make out so if someone else reads this with the same problem it will help them out too.
Mar 13, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't spin or drain
if it can't drain then it won't spin,something could be jammed in the pump,the clutch isn't falling on the trans. what does it do when it goes into spin cycle'do you hear any noises.when it does go into spin cycle listen if nothihng hapeens open the lid and close it listen to see if the clutch falls
Mar 06, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
The water wont drain what should i do, our what part should i buy?
Your part (lid switch)
Remove number 16 (each side )
Video how to bypass
This washer lid switch won't allow for wash or spin or pump if the lid switch is broken.
If the switch is ok then check the motor start capacitor. If it turns out to be good then yall need a timer. Or sometimes that timer connection will back out a hair from vibration shove it back in nice and tight.
Aug 16, 2011 | Whirlpool GSX9885J Top Load Washer
My kenmore washer won't drain or spin. I took out all the water & it still won't spin. I hear the lid "click" and I hear a "hum" when I turn the knob to spin, but nothing else...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jan 27, 2011 | Kenmore 24032\24036 Top Load Washer
My washing machine washes but when it comes to throw the water out and rinse it stops it dosent work .
Dec 08, 2010 | Kenmore 23012 Top Load Washer
HOW DO I BYPASS KENMORE SERIES 80 LID SWITCH ON THE WASHER. IT WILL NOT SPIN , BSD LID SWITCH.
Jun 07, 2010 | Kenmore 22942 Top Load Washer
Sears Kenmore automatic washer model# 110.82872120 (Kinda old) no longer drains. I think it could be the pump or a relay/switch going to the pump. How do I find a schematic to diagnose the problem. I have...
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.82872120&pathTaken=partSearch
Also see the Whirlpool / Kenmore Service Manual for these washers:
If it will neither drain NOR spin, the problem points to the Lid Switch.
If it works, the Lid Switch is a relatively inexpensive part.
If it WILL spin but simply won't drain, the problem points to the pump or hoses. The motor directly drives the pump when in spin mode.
I'd pull the cabinet and check the hoses for blockage, and check the pump to make sure it turns and isn't blocked inside.
Apr 19, 2010 | Kenmore Washing Machines
Washer wont spin or drain
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Apr 14, 2010 | Kenmore 24032\24036 Top Load Washer
WASHER FILL, NO PROBLEMS AGITATING, WHEN TIME
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
Following is an illustrated description of how to remove the cabinet on Kenmore / Whirlpool top load direct drive washers.
Since it won't drain, the problem points to the lid switch. You already have the cabinet off so replacing the switch isn't too difficult.
The Sears site has the Sears (and probably Whirlpool) part number.
Oct 08, 2009 | Washing Machines
Kenmore 16812 Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
