Question about Singer Featherweight II 117
Where to put oil so no parts of the machine get rusty?
  • 17,129 Answers
There are only spots indentified in the moving sections of the shaft and bottom bobbin drives, the motor drives.
Not much of oil is required as it might spillover but just to keep it wet and in only these oil hole points seen,.most ot it on the underside.
Posted on Sep 27, 2010
Where do i put the oil?
one drop, just one drop, on each moving part where two pieces of metal touch each other.
Jul 21, 2015 | Sewing Machines
PFAFF 1222E locked up. Has been siting for some time. Any advice?
Most sewing machine technicians would not recommend using WD-40. Instead, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store and apply a drop every place that metal rubs on metal. However, AVOID oiling any plastic gears! It is also not a particularly good idea to force parts to move as they could break. If they are frozen from lack of lubrication, the Tri-Flow, along with heated air from a handheld hair dryer directed at the metal parts will most often free them up. (Repeat the process as needed.)
Here is a web site that talks about issues with the plastic gears breaking/cracking on this particular machine, so this may also be your issue:
sewing patternreview com
Jun 26, 2015 | PfaFF Sewing Machines
Is the motor in my kenmore sewing machine bad?
will the motor run if you turn it by hand when the power is on
Apr 02, 2014 | Sewing Machines
I just bought a brand new Juki DDL 8100 single needle. I am not able to loosen the screws for the foot and the feeddog plate.I tried narrow,wide, long and short screwdrivers, I also tried to oil the area...
long screwdrivers only please. u need to grind the tip of driver to fit screw head perfectly. stand over machine with all your weight on end of driver. don't use oil u need a penetrating oil . wd-40 will work. let it sit for a few hours the wipe clean. u can try raping the parts with a light hammer too.
Sep 07, 2013 | Juki Sewing Machines
Cannot turn hand wheel or sew.
Have you checked the bobbin compartment to make sure there isn't a thread-jam there? It can get so tightly snarled that even the handwheel won't turn.
Aug 08, 2017 | Sewing Machines
My Necchi 537fa is sewing sluggish. Motor spins but needle moves slow. What do I do to fix this?
If your Necchi has an external motor, take the belt off and run it.... is the motor sluggish? If so... that's where you start. motors need to be oiled, typically with oil and grease ports on either end of the motor housing.
If the motor spins up nicely,... you need to clean and oil the rest of the machine. Start underneath if the bottom workings are exposed, oil all the places where metal joins metal. Then do the bobbin and feed dog area... then look along the top and sides for oil parts.. give them a drop or two...Finally, see if you can get into the head where the take up lever and such are... oil the needle bar, presser foot bar, etc.
It's a dirty job... so prepare a good space for your machine. Liquid Wrench will help you free up gunked up and rusty parts. Fine grade steel wool (0000) and Cotton swabs help.
Good luck
Oct 10, 2012 | Necchi 3537 Mechanical Sewing Machine
Where do I put oil drops in my janone 2049, sometimes it gets stuck
Put just one drop of good quality sewing machine oil on moving parts. You can set machine back gently on towel. Remove bottom plate by removing each screw. Set each screw in a bowl so they don't roll anywhere. I have 30 years experience, so I personally run my machines when oiling so I can observe the parts that move. I d on't recommend this if you have pets & children, and leave that up to you! You should probably unplug machine and just look for anything that is NOT a gear, and just put one drop oil on those parts. Singer lubricant should go on actual gears, but ONLY if not already "greasy". Reassemble bottom plate. If your machine left front section opens up, one drop on those moving parts, and smear one drop of oil on hook. One drop top of needle bar. Do NOT oil or lube plastic parts. Never use cooking oil or bath oil; it will coagulate & damage machine. Always run machine with a scrap of fabric for a bit to distribute oil and to make sure excess does not get on your good fabric. Then rethread machine and replace bobbin and put fresh needle in. Yes, removed thread, bobbin, and needle BEFORE you lube & oil. Did this help? Best of days and nights sewing, Jimmy
Mar 31, 2012 | Sewing Machines
Motor is noisy
I think you need to oil your machine. Clean out any fluff (lint) from inside the machine first. Look at the specific points to oil in your user's manual. Use only sewing machine oil. As a motor is made of moving parts these must be oiled from time to time so that they can move smoothly and do not become rusty.
Aug 18, 2010 | Janome MyLock 634D Mechanical Sewing...
Bernina Record 930 Electronic, seldom use, like new. Wheel will not move. Was doing stright sewing, machine slowed down then froze. Maching is clean. No instruction book or manual. Machine belongs to my...
Bernina 930 Records are notorious for the basting stitch sticking which eventually locks up the machine. To prevent this from happening, be sure to run the basting stitch for a few minutes every month. If it is stuck, you'll need to take it to a Bernina technician.
If it is not the basting stitch, it could be a broken plastic gear (trip to the Bernina technician) or it needs oiling.
If it is not a broken gear, then it probably needs oiling. Your Bernina mechanical requires regular oiling and cleaning even if you don't use it (ie, every time you change the bobbin, every 8 hours of sewing, or every 6 months if not in use). HINT: recommend Bernina oil or similar good quality oil for mechanical machines, NOT 3-in-1 oil, WD-40, or cooking oil!!! One or two drops of oil in every oil hole and every place that metal part rubs against metal part.
Treat your Bernina well and it will serve you well for many years.
Oct 23, 2009 | Bernina Sewing Machines
Singer Featherweight II 117 Logo
54 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
