Question about Sanyo PLC-XU51 Multimedia Projector
Sanyo plc-xu51 switches off 5 - 10 seconds after completing the blue-screen warm-up cycle. Any clues
  • Sanyo Master
  • 11,800 Answers
It switches off because the power source detects and overcharge and shuts itself down for protection.
The projector must be dismantled and tested : start with the bulb (look at it, if it'd blackened you will have to replace it) and the voltages at it. Then test the power source for failing capacitors and lower than normal voltages - sign of a failing component.
Posted on Sep 27, 2010
Why does my Sanyo PLC-XU51 projector power light blink red?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
May 25, 2014 | Sanyo Office Equipment & Supplies
Lamp replace light is still one even though i replaced the bulb
I'm having this same problem. The Ready light is on Green and the LAMP light is on Red. Replace Lamp light is also on. The device turns on, displays the blue SANYO boot screen for a few seconds, then shuts off.
Jul 14, 2010 | Sanyo PLC XP41 Multimedia Projector
Unable to play live tv from lap top to projector
Is it just the live tv or the laptop in general you are not getting a signal from? Using 15 pin VGA cable correct from laptop to projector?
When booted to projector, on laptop, select "FN" key and either F5, F7 or F8 depending on your laptop. Look for the monitor logo on the F keys. This is telling the computer that you have hooked up an additional external monitor (the projector). Once will send image to projector, twice will display on both, a third time will return to just image on laptop.
Jun 17, 2010 | Sanyo PLC-XU51 Multimedia Projector
New globe - instructions not in english
http://online.projectordoctor.com/PLC-XU51
they have the lamp for about $300 (scroll down the page for the cheaper one).
Sep 11, 2009 | Sanyo PLC-XU51 LCD Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
COLOUR
you have to buy a new lamp. i think it`s lmp 14 from sanyo. we have the same plc xr 70 and if you are interestet, we have two lamps and one of them you could have for a special price.
Nov 27, 2007 | Televison & Video
Sanyo PLC-XU51 Multimedia Projector Logo
99 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
