Question about RCA 32V420T 32" TV
I have a 32" RCA 32V432T TV that only shows snow now. I've checked everything externally but still no picture. Any solutions?
  • 40 Answers
There could be several things that can cause this: 1. There are no analog channels in your area. 2. Check the menu setup and verify that you select the proper input (antenna, cable, etc). 3. The TV tuner is defective Try using the composite input on the TV (there are normally 3 jacks per input). Yellow for video and red and black for audio. If you dont have the proper cable, pick one up in you local 99 cent store or an electronic store.
Connect the "output" of your device (VCR, cable box, Tivo, dvd player, etc) to the "input" on the TV. Then use your TV remote to select the proper input.
Hopefully this helps. Good luck.
Posted on Sep 27, 2010
Rca 32" 32v432t
What is the problem with your RCA TV? Provide some more details, please.
Jun 23, 2012 | RCA TruFlat 27F520T 27" TV
I have an 32 rca t.v my son has locked and won't
I got this from the manual. Page 26.
Press MENU to see the main menu.
Press CH+ or CH- to highlight preferences.
Press OK to enter the preference submenu.
Press CH+ or CH- to highlight Par. (Parental) Control.
Press OK. Enter Password will appear on the screen.
If you want to set a new code, go to steps 6-8 directly. (You can press the number buttons to enter a four-digit code. The code "0000" is the default password. If you have not set a code previously, then "0000" is the code.)
Resetting Your Password
Press VOL+ on the remote and the CHANNEL + on the front of the TV at the same time. Enter New Pwd. will appear on the screen. (You must be in the Enter Password screen when attempting this.)
Press the number buttons to enter a four-digit code. The code will appear on the screen as you enter it.
Press OK to save the code.
Press MENU repeatedly to exit the menu or the menu will automatically disappear within a few seconds if no buttons are pressed on the remote control.
If you need more, get the manual here:
http://www.retrevo.com/support/RCA-32V432T-TVs-manual/id/402ci372/t/2/
Pages 25 through 30 are all about lock and channel/show blocking.
Jun 05, 2012 | RCA Televison & Video
I have two RCA 32v432t tv one want power up and the fuse is good I see no burns on the board and no burn smell and every shop i call say it's cheaper to by another one is it' ?
This sets just dont hold up. CK hori output transistor and Bad FBT flyback Transfomer.
Also try with TV off Press and hold CH- VOL- at same time and see if TV will try to come on.
Dec 27, 2010 | RCA 32V420T 32" TV
I`ve a RCA L32wd14 tv everything works fine but
Tries Unplug,replug the tv about an hour,go to the menu sound setting reset it back to factory setting.Should work after this.Not than ur Main Tuner signal board have problem.Must replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner board for the replacement.
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
Rca tv model 32v432t
This set is not digital tuning and you would need a converter for off-the-air reception. You can get full specs and manual downloads from RCA's site:
http://tv.rca.com/en-us/productdownloads.html?MN=32V432T
Nov 18, 2008 | RCA 32V420T 32" TV
32" rca picture stretched
Before you fool around with this, it may be under warranty. Check that first. Second, does the picture stretch in both directions or just vertically? If just vertically is it more pronounced at the top?
Thanks,
Dan
Apr 03, 2008 | RCA 32V420T 32" TV
Rca 32v432t
You need the factory remote only for this model of set!
Contact the service rep for your set and order a new remote.
As for the service mode, most RCA sets require an external service interface.
In many models of sets, the results and commands are in HEX. You will need the service manuals, hardware interface, and instrumentation to do proper setups and adjustments.
As for accuracy of adjustments, from factory these sets were very accurate. If there are changes, this is due to failing parts, and not from adjustments going out. The setups are all uPC controled and are exact. The set should be serviced to make it work properly, and not adjusted to offset faults.
Jerry G.
Dec 23, 2007 | RCA 32V420T 32" TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Picture problem when I use an external antennae
You cant unless you have been trained to trouble shoot solid state electronics as this set has no user serviceable parts inside and is best left to the pro tech to service. good Luck
Aug 08, 2006 | RCA F27645 27" TV
RCA 32V420T 32" TV Logo
114 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
