Question about Samsung Cell Phones
Fully recharging battery and it is drained within 1 hour.
    Problem Solver:
  • 3 Answers
Your battery has likely been over charged. When this happens the battery itself may swell up.(become thicker). If you remove the battery and find it difficult to place it back into the casing, this swelling is likely the cause.
An overcharged battery needs to be replaced.
Posted on May 23, 2008
How long to recharge a 18v dewalt drill battery
A fully working 18v Dewalt Battery will only take 90 minutes to just over an hour to fully charge from going flat. This fully charged battery should last about 4 hours of use (depending on the load). So the answer is 1 hour.
Aug 11, 2013 | Drills
Battery charge is only good for 15to20 seconds---24volt-----bought aug 2010 ---l24wg165x1p-----serial#45667----please advise soon as possible------j.campbell ---phone419-836-5516------cell...
Your battery has probably just reached the end of it's service life, or developed a memory after repeated chargeings without being fully depleted. All rechargeable batteries have an average maximum number of duty cycles. (drain and charge) If your charger has a deep cycle feature, try using this to completely drain and recharge the battery. If it doesn't, try putting it in your trimmer and locking the trigger back for a few hours, then recharge it. If neither of these work, it's time for a new battery. If you do get a new battery, be sure to COMPLETELY drain the battery before recharging by locking the trigger back every few uses to avoid developing a memory and help extend the life of your new battery.
May 31, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Hello, i am from Greece and i represent one young and famous Greek singer.We use the psm 900 on stage and the batteries need to be replaced within one hour from the first use.So, we need to do this 2-3...
Shure's spec is that you should get 5 to 7 hours of CONTINUOUS use. There is OBVIOUSLY a problem.
First thing to check is what brand batteries you are using... some cheap ones from "C" have only a fraction of the energy content as name brand ones.
Second thing is expiration date on the batteries.
Next is to check the current drain of the bodypack with aa meter and compare to the specs for the battery. A good AA should deliver 2000 maHr.
The last thing is to realize that you CANNOT use rechargeable batteries in these devices. The rechargeables have a lower voltage and the circuitry will cut off MUCH earlier than with alkaline batteries. I would expect rechargeables to fail within 1 to 1.5 hours in this unit. As the rechargeables age, it would become much worse.
Mar 04, 2011 | Shure PSM 900 Bodypack Receiver
The battery is fully charged and loses the charge within 15 minutes of being fully charged. Battery is 18 months old!!!!! Help
Simple fix turn on the puter on the logo screen press F10 to go into bios setup page scroll over to battery calibration on the tabs on top you will see HDD and Battery choose battery.
Now hit calibrate.
1- Recharge
2- Discharge
2- Recharge
Let the puter complete all of the sessions without interruptions.
That will calibrate your battery to charge correctly. thanks.
Nov 07, 2010 | HP Compaq Evo n610c Notebook
How many hours we should charge the battery fist time Nokia-2700
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Oct 07, 2010 | Nokia N70 Cellular Phone
What is the maximum charging time of drained batteries?
There is no maximum - it will not harm the batteries if you leave it on charge too long. The minimum time to fully recharge should be 3 to 6 hours depending on the power source. If you are using a mains charger it should fully recharge in 3 hours, but longer if you are charging via a usb cable from a pc.
Mar 30, 2010 | Nokia E63 Cell Phone
Mp3player 2gb smp2012
most of the time when your plugged into the pc it will charge see if this is true for your player if so leave it on the the pc for a few hours also drain the battery fully then charge for a few hours
Sep 15, 2009 | RCA M4204 MP3 Player
Quick battery drain
No sorry to say this is normal for this camera! you may want to look for rechargable lithium batterys (they will last longer in a high drain device such as your camera!
Please rate my answer!
THANK YOU!
Jan 12, 2009 | Fuji FinePix S7000 Digital Camera
Power drain?
try to replace new rechargeable battery, recharge it in specified of numbers of hours.
Dec 25, 2007 | Pentax K100D Digital Camera
Cell Phones Logo
127 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
