Question about Sony (ICSSP20) TV Input
How to undo safe mode on sony bravia tv. My when switch on works for 10 to 20 minutes then go to safe mode. The screed turn black. and show red indicator light. Please provide the solution
  • rotichdk Sep 27, 2010
    I said my TV SONY when switch on works for 20/10mins then the screen goes black. I need the solution. Could it be something to do with programming ?
    iam not satisfied with the explaination Give.
    Okay which compnent then get burns on this model of TV.
Is your televison connected to a PC?
Posted on Sep 27, 2010
  • Sony Master
  • 11,800 Answers
This isn't safe mode, what you see is the result of a failing component inside your tv going bad and sending the power source in the protected mode.
The tv must be opened and tested to identify and replace the defective part. This is a job that should be left to a professional repairman, if you don't know exactly what you're doing you could mess it even further.
  • Azrael SRL Sep 27, 2010
    No, it's not a programming error - an actual electronic part inside the tv heats up and starts to behave badly so the power source shuts down to protect the rest of the tv.
    There are over 10,000 components in that tv, without testing only god could tell you which failed. I'm not god so all i can do it tell you that, based on the time it takes to heat up and start to malfunction, the failed part is located on the mainboard.
Red flashes 6 times and pause for three secs
Using the remote, open the system menu and reset the tv.
Mar 07, 2015 | Sony Bravia Kdl-55ex500 55 Tv, Series Lcd...
Sony KDL32CX520 red light blink 5 times
IKR Error at power on 05. 5 blinks denotes this. Actually, the fault is related to its main digital board, and the work will not an easy one. Anyway, http://electronicshelponline.blogspot.com/ check this link. Pull up previous posts there, either by its left side bar, or view it in Timslide option, and see whether there is something to help you. If you're not sound in electronics, no need to proceed. Contact any service technician or authorized service centre for Sony.
Jun 29, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My Sony bravia kdl55hx800 lcd 3d tv won't turn on
try unplugging your t.v for a few minutes, then plug it back in. if it continues check your owners manual or google your issue. this might be the red flash of death. hopefully unplugging it works. good luck!
May 18, 2011 | Sony Televison & Video
I ve Sony Bravia KDL55EX713 55" TV, it keep showing me input banner showing(Bravia,LED,presence sensor,Motion flow,Full HD, BE3, WIFI HDMI etc.) I have tried display button, and all settings on...
Your TV is in store demo mode.
To fix this, access the TV's menu and find the option to run initial setup. At the beginning of initial set-up, you'll be asked whether or not the TV should be put into Home or Retail mode. Choose Home.
Mar 15, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Mar 14, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony (ICSSP20) TV Input Logo
1,141 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
