Question about Refrigerators
Lost operation manual for best temperature settings and fast freeze option, are these instructions available, please? Thank you :)
  • ritaw22 Sep 27, 2010
    sorry I thought it went through with my search info...Lemair FR-180V
    sorry, never used this site before so I'm fumbling through here...it's a Lemair FR - 180V upright single door freezer. Thanks :)
  • 10,515 Answers
Kindly mention the make and model of the refrigerator?
Thanks!!
Posted on Sep 27, 2010
  • taran_2005
    taran_2005 Sep 27, 2010
    Thanks for your response!!
    Unfortunately, i do not see the manual for this model. This brand was made in China. So, it is really tough to get a manual for this model. You could reject my solution and then the question would again be in queue. I hope some other expert would be able to help you with the manual.
    Thanks!!
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
Lost owners manual
You only require fast freeze if you are using the freezer for the first time, after a defrost, or if you add a large quantity of fresh food to an already running freezer. Most freezers require about eight hours at fast freeze. As to the temperature setting I would suggest you purchase a purpose built freezer thermometer (very cheap) and place that on top of the food. With the thermostat control set mid way (about 3 or 4) check the thermometer occasionally see what the temperature reads. It should be around -18C, if it's lower then set the thermostat lower at 2-3, if its higher set the thermostat higher at 4-5. Repeat this until the freezer temperature is correct.
Dec 26, 2013 | Haier 3.6 cu. ft. / 102 liter Chest...
Manual for lemair freezer model fr-120v
I have the manual.
From the Left:
(1) The "!" is the red warning indicator - indicates if the temperature is currently lower than set.
(2) "I" is the green power indicator,
(3) "S" is the Yellow Fast Freeze indicator,
(4) "S" is the Fast Freeze switch/button,
(5) "I" is the Off/On switch/button.
(6) - with the coin slot - is the Temperature Regulator.
(I have mine 1/2 way around the dial.)
Sep 18, 2012 | Refrigerators
Owner Manual or Operating Instructions
Could this be the one?
www.esmithair.com/manuals/Comfort_Zone_II.pdf
If not,please let me know your models name and number through the [Fixya] comments option.If yes please rate the answer.
Thanks!
Ken.
Jan 22, 2012 | Comfort Zone Heating & Cooling
I have a ge profile side by side refrigerator model number psc25psta. The freeze is not getting cold. How do I reset the temperature.
Here is a link to the main GE Support page for your refridgerator:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PSB42YSXSS
And here is a link to the Online User's Manual with the operating instruction for it:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60558.pdf
See page 5 of the User Manual for detailed instructions on how to adjust the fridge and freezer temperatures. It reads as follows in the manual:
To change the temperature, press and release
the WARMER or COLDER button. SET will illuminate in
the display, as well as the set temperature. To change
the temperature, tap either the WARMER or COLDER
button (while SET is illuminated) until the desired
temperature is displayed. Refrigerator temperatures
can be adjusted between 34F and 47F and
the freezer temperatures can be adjusted
between 6F and +8F.
Once the desired temperature has been set,
the temperature display will clear after 10 seconds.
To display the temperature, the DISPLAY TEMP button
may be tapped.
Several adjustments may be required. Each time you
adjust controls, allow 24 hours for the refrigerator to
reach the temperature you have set.
Good luck and please comment back here and RATE 4 Thumbs Up if this was at all helpful.
Just click on the highlighted links with your mouse in order to access the information described.
If the link does not open properly, you may need to download a PDF Reader program for your computer. The best reader can be downloaded free at www.adobe.com where you just click on the DOWNLOAD ADOBE READER button on the right hand side of the page and follow the on-screen instructions.
Just comment back here if you require any further assistance, I will be pleased to assist you in any way I can.
Thank you very much.
Joe.
Feb 14, 2011 | GE Profile PSB42YSXSS Stainless Steel (252...
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
