Question about Garden
I have an old Craftsman type I corded electric drill that I love. It's from the early 1970's (probably 1973). Until two weeks ago it worked great but stopped when it fell from a workbench. Is it worth trying to fix? Do you have some tips on how and where? It does get power through the line to the drill but not beyond.
    Problem Solver:
  • 19 Answers
First, be safe if you are planning on opening the drill. Make sure the cord is unplugged. Check the motor to see if any of the wires look severed or a brush is loose. Most newer drills are more powerful, even for the inexpensive ones, than the older drills. They also tend to use much less power. So the recommendation is, if it is not for sentimental purposes, a new drill might be in order.
Posted on Sep 27, 2010
The drill shuts off when cord moves.
What has likely happened is one of the wires, white or black, inside the black plastic electric cord has fractured.
This is really common on electric hand tools that are either over 5 years old or are well-used.
I can't count how many times it has happened to me!
You will need to somehow cut the cord off at the bad spot, and rewire the end of the cord into the end of the drill handle.
Won't be easy, but you can do it.
Many more modern tools have a reinforced sleeve of about 2 inches at this weak spot.
God bless your efforts.
Apr 07, 2016 | Drills
My corded drill only works in reverse
Your R/L switch is probably faulty. Sometimes the little pin on top of the switch brakes off.
Jan 23, 2013 | Craftsman 3/8" Corded Drill
I need to replace a cord on an old Craftsman 1/2" drill
A lot of times B&D makes molded cords that work with Craftsman stuff. Look up a service center near you and take the cord in to see if they can match it up with something they have. (Take the drill in too.)
http://dewalt.com/Find-Service-Center.aspx
Apr 22, 2012 | Craftsman Drills
Craftsman Model #315.271690 3/8 Professional Electric Drill (corded). What are the specifications (dia, threads per inch, etc.) of the left hand thread machine screw that holds the chuck on. The Sears...
How do you remove the chuck from a Craftsman Model #315.11441 3/8 vsr corded drill? Am trying to remove the chuck but I believe there is some type of a set screw or locking mechanism that needs to be undone. I can see a slotted screw head in the chuck Looking straight down on it but it is very tight and I don't want to break it or a screwdriver forcing it. Thanks for input. Bob
Sep 06, 2010 | Craftsman Drills
I have an old 315-11441 Craftsman Drill. I took it apart to fix the switch and in the process something must have shifted in or around the gearing. After putting back together when I power the drill I hear...
With these types of electric motors there is an armature, (the main brain of the motor) it has all the copper wiring wrapped around it and slides between two carbon brushes into the armature housing. If you took out the armature, there is sometimes a very thin peice of metal at the top of the armature which slides into the plastic housing above the armarture and creates a spring loaded "seat" for the armature, if this little shim looking thing fell out, you will need to find the old one. Without this tiny peice of metal the armature in the motor will have play in it causing the brushes to wear to one side or the other prematurely, the brushes have to wear evenly. Sometimes the brushes are spring loaded as well for a self-feed type deal. If these springs are missing the same thing will happen. Also one or both brushes could be in backwards. Check and make sure the brushes (black carbon and rectangular shaped) are positioned to support the spin of the armature. Lord, I hope this helps. I worked with small electronic motors over 15 years ago. I worked at the place for a few months, and didn't think I still remembered everything,
Aug 12, 2010 | Craftsman 3/8" Corded Drill
I have a craftsman electric drill model no. 315.10419, i would like to know how to loosen/tighten the chuck for the bits. it is not the regular notched tightener but has a pull down shaft similar to an...
I have the same drill and love it !! This series of Craftsman Drills are the first of the keyless chuck. To tighten or loosen the bit, simply pull back on the black ring tightly and hold it and simultaneously pull trigger to run drill foreward (to tighten bit). Reverse (to loosen bit). The chuck will make a loud clicking sound!! This is normal !
Jun 23, 2010 | Craftsman Drills
Manual for 1950 Craftsman Drill Press
Not sure if you ever found the manual for this model number. I just picked one up at a garage sale last weekend and it actualy had the manual with it. Doesn't really go into any overhaul of the machine, but does have a exploded view of the parts.b329678.jpg
Feb 14, 2010 | Craftsman Drills
Died and will NOT start.
I experienced a similar problem with mine and I replace the little plastic tube that is immersed into the fuel. It had some stuff in it and preventing fuel from getting to the engine. It was only about 1.50 to replace.
Jan 05, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
