Question about Kenmore Washing Machines
Kenmore Series 80: Machine does not drain or spin at the spin cycle.
  • Kenmore Master
  • 17,130 Answers
Make sure there is voltage present to the motor when the cycle is ON>
If not the program controller is faulty, If yes the motor must be checked for errors.
Since both the drain and spin is not working the fault seems to be from the program controller as there is no output to the drain and motor.
So check the controller for the lack of output, try choosing a different program cycle to confirm..
Posted on Sep 27, 2010
My kenmore series 80 washing machine makes a clicking sound during the spin cycle.
Might be something lodged in the drain pipe on the drum, such as a coin or similar object.
Dec 20, 2011 | Kenmore Washing Machines
We have an 80 series washing machine that will go through all cycles until it is supposed to drain then nothing happens. It wont go any further .
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 29, 2011 | Kenmore Refrigerators
My kenmore 80 series washing machine will not always drain out on the spin cycle and sometimes when it does there is dirt in the tub under the clothes. why?
heatman101
Apr 02, 2011 | Washing Machines
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Machine will wash but not spin or drain-Kenmore series 80
needs a new drain pump you can replace it easily by leaning the washer back at a 45 degree angle then right at the front panel you will see the 2 hoses hooked up on the drain pump there is a clip on top and bottom of it unclip them and slide the pump off the motor shaft then undo the hoses and do in reverse order to replace and please rate me
Jan 05, 2009 | Kenmore Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
74 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
