Question about Car Audio & Video
CD player When inserting a cd into the car stero it spits the cd out and gives an error 07. We have tried cleaning with compressed air, and we have cleaned the cd's and even tried new cd's. Could you please tell me what is causing this error?
    Sergeant:
    Champion:
  • 359 Answers
It sounds like the laser is gone depending on what the stereo is worth u would be better off replacing it
Posted on May 23, 2008
False read on CD player. No cd inserted , player states cd in.
remove the cover and clean the lens with a cotton bud and cleaning solution (spit ).Works every time and still to this day.
In failing that, then a new cd player.
Feb 08, 2016 | 2010 Toyota Camry LE
I keep getting the CD E-01 error, but all my CDs are brand new and very clean, what should I do ?
Get a can of compressed air from a local office supply store or walmart and insert the supplied straw into the cd player and blow away the dust on the lense.
Dec 01, 2010 | Blaupunkt RPD 552 CD Player
Cd player wont play
put a cd cleaner in to clean the heads so it can read the cd
Nov 13, 2009 | 2002 Volkswagen Golf
CD BURNER NEED TO BE CLEANED BUT YOU CANT TAKE IT OUT
go to computer store and get a CD or DVD cleaner disc. and a can of compressed air.
open the CD buner door and use the compress air, then insert the Disc and let it run few times.
Apr 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Spits out my cd's
I had this Problem in My 95' Silverado. It was going to Cost as Much to Repair as it would for a New Unit. So, I just Replaced the Head Unit with Aftermarket Pioneer and Took it out. Not the Same Vehicle But, Same Principle.
Jan 22, 2009 | 2003 Saturn VUE
I HAVE A STRD711 AMP MY PROTECTOR KEEPS FLASHING AND CAN'T GET STERO TO WORK CAN U HELP
Try opening up the unit and giving the insides a good cleaning with a can of compressed air. That might help.
Aug 24, 2008 | Sony Audio Players & Recorders
No Disc
Initially, try cleaning the lens using a CD ROM disc cleaner similar to those used in PC's CD ROM drives. They are normally and readily available from most computer shoppes. If the cleaning would not be corrective, pls try to manually clean by opening and use cotton buds to clean the laser/optics. it may also be worth your while to spray the insides with a can of compressed air to remove dust. Re-application of lubricant to the mechanical portion would also help.
If none of the above solves the problem, then chances are that the laser wiould require replacment. Considering the cost of repair and downtime, it might be more economical to purchase a new unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 21, 2008 | Pioneer DV-270-S DVD Player
My emachine computer T1105 just stop working when i insert the restore CD it say "ERROR 0200: FAILURE FIX DISK 0
1. Make certain the caqble connecting the CD drive and the motherboard is secure.
power down the computer
remove the power cord
open the case
GROUND YOURSELF ON BARE METAL
trace the wide ribbon cable connecting the CD drive to the motherboard and make certain it is firmly seated at both ends
(while you have the case open and yourself grounded, grab your can of compressed air and blow out some dust bunnies, OK? :-))
close the case, plug in, power on.
If that wasn't the issue,
2. Clean the restore CD by using a soft cloth and wiping from the inside (at the hole) stright to the outside edge. DO NOT wipe in a circular motion!
3. Purchase a CD/DVD drive cleaning kit from WallyWorld or some other discount house and attempt to use it to clean the drive. DO NOT use compressed air to clean the drive!
4. Report back. :-)
Jul 17, 2008 | Computers & Internet
Rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Oct 17, 2007 | Blaupunkt RPD 552 CD Player
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
