How do i change the thermocoupler in my water heater? do i have to remove gas line or just bend out of way?
    President:
  • 1,796 Answers
Hi!!
The thermocouple screws into the thermostat unit and the other end is fastened by a small clamp right by the pilot flame. Make sure the unit is off and the gas supply is shut before working on the unit. Loosen the fastening screw inside the unit, unscrew thermocouple from thermostat unit and remove it. The only times you remove the burner, is when the fastening screw gets stripped or is too hard to turn.
Good Luck!!
Posted on Sep 27, 2010
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Tip
How to Change the Gas Valve and Thermostat on a Hot Water Heater
<p>If you are having<b> trouble with the temperatures</b> of your <b>gas hot water heater</b> fluctuating too much, or after <b>changing the thermocouple</b> of your gas <b>hot water heater</b> then you may need to change the complete <b>gas valve and thermostat assembly</b>. Also if you have changed the <b>thermocouple</b> and the pilot still will not stay lit, then the gas valve could be bad or the <b>ECO (Emergency Cutout)</b> may have activated and is open. This is a onetime device and cannot be replaced.<br /> <p><br /> <p>These instructions are for the older style <b>gas valve and thermostat combination</b>. These commonly have a large red knob that adjusts the temperature of the water. Also note that the burner tube nut for <b>natural gas</b> is right hand thread, but if you have <b>LP or propane gas</b> the burner tube nut is left hand thread.<br /> <p><br /> <p>The newer <b>gas valve thermostat combinations</b> that have come out recently are similar, but they have a well in the tank that the sensor slides into. The assembly is held fast with a set screw. With this type of <b>gas valve and thermostat unit </b>the tank does not need to be drained, but most of the rest of the change out is similar.<br /><br />To change a <b>gas hot water heater thermostat</b> you will need to first buy a new gas valve for your <b>hot water heater</b>. The <b>gas valve</b> and the <b>thermostat</b> are integrated into one unit.<br /><br />To <b>replace the thermostat on a gas hot water heater</b> you must follow these procedures....<br /><br />1. Turn off the incoming water and<b> drain the hot water heater</b>.<br /><br />2. Remove the <b>pilot tube</b>, the <b>burner gas tube</b> and the thermocouple from the gas valve. Turn off the <b>gas line</b> and remove from the gas valve.<br /><br />3. Get a <b>pump pliers</b> or a<b> wrench</b> in behind the gas valve and turn the whole assembly CCW to remove it from the tank.<br /><br />4. After applying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the <b>ECO</b>. They are the little red wires on the back. If you break them the assembly is irreparably damaged.<br /><br />5. Reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.<br /><br />6. Fill tank with water. Make sure to open a <b>hot water faucet</b> and <b>purge all air from the tank.<br /><br /></b>7. <b>Check for leaks</b> where the gas line hooks up with soapy water.<br /><br />8. Relight pilot light and check operation.<br /><br />9. Set the new temperature setting to a medium setting and then adjust the temperature to your liking from there and adequate time for heating completely<br /> <p>
on Feb 25, 2011 | Water Heaters
I have a whrilpool water heater model fg1f404053nov replaced the thermocouple, stays lit for a couple of days and goes out....change out the gas vavle ???
Resources for Whirlpool/Craftmaster gas water heater:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Problem might be diminished air supply or bad venting. Clean the air intake located on bottom of water heater using compressed air or feather duster. Air intake screen is series of openings as wide as razor blade and can easily clog.
Clean the combustion parts and burner. Bleed air/water out of gas line. Check gas pressure.
Check for pilot and venting issues on link above, including tight house, and other gas appliances and vent fans pulling draft down the water heater vent pipe, etc.
Also see service manuals for each type of gas control valve, and replacement steps for each type.
Mar 16, 2013 | Whirlpool Water Heaters
Pilot light will not stay light
1) Open following link for how-to resources, illustrations, and service manuals for some brands of heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
2) Many things can cause pilot problems, including bad thermocouple, air in gas line, low gas pressure, negative pressure in house, bad venting, very hot attic, lack of combustion air, dirty combustion parts and dirty pilot tube, bad gas control, reversed polarity on electrical outlet.
3) If pilot flame is clear blue and strong, then next step is check that thermocouple sits in the flame, and then change thermocouple. This is start point. Following step would be reading service manual for exact troubleshoot and testing steps.
4) If pilot flame is yellow-or-orange or weak, then clean dirty combustion parts including pilot tube and air intake. Might want to change thermocouple while combustion parts are removed for cleaning.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
I have a reliance 501 propane gas water heater how do i change a thermostate
To change a gas hot water heater thermostat you will need to first buy a new gas valve for your hot water heater. The gas vaive and the thermostat are integrated into one unit.
To replace the thermostat on a gas hot water heater you must follow these procedures....
1. Turn off the incoming water and drain the water heater.
2. remove the pilot tube, the burner gas tube and the thermocouple from the gas valve. Turn off the gas line and remove from the gas valve.
3. get a pump pliers or a wrench in behind the gas valve and turn the whole assembly CCW to remove it from the tank.
4. After appliying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the ECO. They are the little red wires on the back. If you break them the assembly is irreparably damaged.
5. reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.
6. Fill tank with water. Make sure to open a hot water faucet and purge all air from the tank.
7. Check for leaks where the gas line hooks up with soapy water.
9. Set the new temperature setting to a medium setting and then adjust the temperature to your likeing from there and adequate time for heating completely.
heatman101
Feb 23, 2011 | RELIANCE ELECTRIC WATER HEATER
I WOULD LIKE TO REPLACE MY THERMO CUPPLING
In simplest terms, a thermocouple is a temperature sensor. Normally inexpensive, a thermocouple is standard on hot water tanks. If your thermocouple breaks or you feel it is not working properly, consider replacing it b?p=y23r90wnbq7oglkvtnbuhgyhrktxauzqpeoaddsf&t=18g7grtjm%2fx%3d1290445898%2fe%3d2143440281%2fr%3dacont%2fk%3d5%2fv%3d8.1%2fw%3d0%2fy%3dyahoo%2ff%3d2680761980%2fh%3dcg49imfjb250iibzzxj2zulkpsjzmjnsotb3tkjxn09nbgtwve5ivuhnewhys1r4yvv6cxbfb0fezfngiibzaxrlswq9ijq4mtmwnteiihrtdg1wpsixmjkwndq1odk4ota5njiwiia-%2fq%3d-1%2fs%3d1%2fj%3d6f060d4c&u=13gohjn6b%2fn%3df8a.bkwnpkw-%2fc%3d715481.14405591.14260180.13829426%2fd%3dlrec%2fb%3d6235626%2fv%3d1 lg.php?category_id=6&content_type=article&content_type_id=584031&key_page=1721642411054458764&site_id=1&bannerid=10089&campaignid=2945&zoneid=2&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html%3fcontent_type_id%3d584031&cb=ebe6534afeavw.php?zoneid=2&cb=1721642411054458764&source=&n=a14de4a9&slice=-1060-&dma=-0-&cty=-us-&content_type=article&content_type_id=584031&category_id=6&key_ad=1045292919&site_id=1&ad_pos=2&key_page=1721642411054458764&ac_url=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html rather than installing a new gas hot water heater.
Begin this project by shutting off the gas control knob on your hot water heater. Once you are sure that the gas is off, you should use a wrench to remove the nut that attaches the thermocouple to the gas hot water tank. This nut should appear to be securing a piece of copper tubing or other type of tubing. With the nut removed, you should also pull down on the tubing, dislodging it from the thermocouple.
Sometimes there is another nut that attaches the end of the thermocouple to the pilot bracket, if this is the case you should unscrew this nut as well. You can slide it down the tubing and keep it there until you need to replace it.
With the nuts that were holding the unit in place removed, you should be able to slide the old thermocouple out of the brackets that hold it to the hot water heater. You should then take it to a hardware or home improvement store and find a suitable replacement. Then follow these steps to install the new part and fix the hot water heater.
To change the thermocouple, you should press the end of the thermocouple into the pilot bracket as far as you can. If you had to remove a second nut to remove the old thermocouple, now is the time to replace that nut securely.
With the thermocouple in place, you should connect the lead to the control unit. Use the nut you removed in the beginning steps to secure the lead. You should then tighten it at least a quarter turn with a wench to make sure the lead is securely attached to the control unit of the gas hot water heater.
Now that the new thermocouple is installed on your gas hot water heater, turn on the gas shut off valve that you turned off earlier. You should be able to relight the pilot and the functionality of your gas hot water heater should be restored.
Dec 06, 2010 | Heating & Cooling
I have old rheem ruud hot water tank. it's down for 4 day's, i would like to get it started, but the thing i would like to find out is can i get it going by lighting it up by using lighter or not. The...
Yes you can light it with a BBQ type lighter (long enough).
If it lights and stays lit then you need to change the thermocouple (looks like a little pipe off gas valve)
In simplest terms, a thermocouple is a temperature sensor. Normally inexpensive, a thermocouple is standard on hot water tanks. If your thermocouple breaks or you feel it is not working properly, consider replacing it b?p=y23r90wnbq7oglkvtnbuhgyhrktxauzqpeoaddsf&t=18g7grtjm%2fx%3d1290445898%2fe%3d2143440281%2fr%3dacont%2fk%3d5%2fv%3d8.1%2fw%3d0%2fy%3dyahoo%2ff%3d2680761980%2fh%3dcg49imfjb250iibzzxj2zulkpsjzmjnsotb3tkjxn09nbgtwve5ivuhnewhys1r4yvv6cxbfb0fezfngiibzaxrlswq9ijq4mtmwnteiihrtdg1wpsixmjkwndq1odk4ota5njiwiia-%2fq%3d-1%2fs%3d1%2fj%3d6f060d4c&u=13gohjn6b%2fn%3df8a.bkwnpkw-%2fc%3d715481.14405591.14260180.13829426%2fd%3dlrec%2fb%3d6235626%2fv%3d1 lg.php?category_id=6&content_type=article&content_type_id=584031&key_page=1721642411054458764&site_id=1&bannerid=10089&campaignid=2945&zoneid=2&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html%3fcontent_type_id%3d584031&cb=ebe6534afe avw.php?zoneid=2&cb=1721642411054458764&source=&n=a14de4a9&slice=-1060-&dma=-0-&cty=-us-&content_type=article&content_type_id=584031&category_id=6&key_ad=1045292919&site_id=1&ad_pos=2&key_page=1721642411054458764&ac_url=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html rather than installing a new gas hot water heater.
Nov 22, 2010 | Heating & Cooling
Gvr 40 100 will not stay lite
The Cold air screen on the bottom of the water heater is partially plugged. That is if the pilot light can be lit and stay on, but goes out when the heater should be functioning normally. This is not the removable plastic screen but a round white-yellow grid with 1/32" holes. You can try to clean it through the bottom but you may have to remove the gas line from the controller to the burner, pilot gas line, and thermocouple connection to remove that complete assembly to get access to the screen. The AO Smith booklet warns of this but they pretend the plastic screen will keep this second screen clean but it won't. After three years it was two thirds plugged.
Dec 12, 2009 | RTO W4 A.O Smith Gas Hot Water Heater...
Whirlpool water heater thermocouple
Nope, turn off all gas to the heater. Remove the enclosure containing the burner. Disconnect both the gas line and the thermocouple line from the gas valve and pull out the whole burner assembly. Take a pair of needle nose plyers and remove the thermocouple from the pilot assembly. Install the new one and reverse the removal procedures to put it all back together. Check to make sure there is no gas leaks and this is important, The nut to turn off the burner tube from the gas valve is reverse threads. Righty to turn off, Leftie to tighten.
Nov 20, 2007 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
