Question about Toshiba Computers & Internet
Computer won't boot up past windows starting up
  • George Rivera May 11, 2010
    Then what happens? Need more info.
  • Obinna Cedric Agugua
    Obinna Cedric Agugua May 11, 2010
    What windows version do you use?
  • 4 Answers
While we wait for more details you may try this:
1 Power off the computer
2 Power it on and press F8 repeatedly while it is booting
3 You will see a list of boot options; choose "last known good configuration" and press enter.
4 It should then boot normally... if it does,
5 Do a system restore (if your version of windows supports that) to an earlier date when your computer worked perfectly.
If that doesn't solve it, restart the process and when you get to number 3, choose "safe mode"
4. After a successful boot, disable all the startup programs that you can do without there. To do this, use regedit or msconfig depending on your windows version. Be careful when using regedit.
5 Reboot and see. Hope these help.
Meanwhile, it would help a lot to post more details.
Posted on May 24, 2008
  • 36 Answers
Hi , try this
Slow Boot and shut down : Go to “RUN” and type in “ regedit”
2) HKEY_LOCAL_MACHINE
3). SYSTEM
4). CurrentControlSet
5). Control (click on control)
6) on right windows pan look for the option : program kill time 20 sec
Posted on May 23, 2008
Ntldr missing computer won,t start
Check or replace data cables to hard drive
Check in bios that drive select is set to auto.
Boot to windows dvd and repair windows start up.
Jan 22, 2014 | Abit KW7 Motherboard
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Nov 13, 2012 | Gateway 3522GZ Notebook
T61 won't go past the Microsoft loading screen
Press F8 during boot, and load Safe Mode. A program may be preventing a proper startup.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 01, 2012 | IBM Lenovo ThinkPad T61 Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
I have a toshiba protege 7100 series and it won't boot past the windows screen
Try hitting F8 during startup and choose last known good configuration.
Or you could try starting in safe mode and doing a system restore.
Have you made any changes to the system prior to this problem, as sometimes installing programs/drivers can cause similar issues. If so you will need to remove or configure the program causing the conflict. You can do this in safe mode.
Mar 13, 2012 | Toshiba Portege 7100 Notebook
Motherboard won't boot past cmos
you are pretty much right it may be a corrupt bios, however before we come to a conclusion try isolating both Seagate Barracuda 7200 rpm 80gig ide hard drive and optical drive only and then see if it at least goes past the bios screen, if yes then the bios is ok and just needs to be resetted to defaults. dont expect it to load windows even if it goes past bios check as hard disk which helps to boot to windows would be removed. also in case if you are using 2 ram slots try connecting only 1 ram chip in 1 slot and then see if it goes past the bios test screen. do reply with results. Good luck.
Feb 08, 2012 | Abit Computers & Internet
Not able to boot press F12 lauch startup repair (30 second) I have to wait keyboard not responding then windows is loading files and start bipping error
first, recover your files. You will need to use something like this data recovery program.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 05, 2011 | Toshiba Computers & Internet
I have a compaq presario cq56-104ca i reformat it to windows 7 ultimate 32bit from home premium 64bit. but now it won't start past the boot screen it freezes when it reaches there. and if i try to...
See if this works otherwise you will have to reload the Operating System in your system.
Switch
ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
1. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A) Click on the Recovery icon.
B) Click on the Open System Restore button.
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time'
A) Click on the Next button
Now you will find a window with Dates, Description and Type,
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks
Aug 02, 2011 | Compaq Computers & Internet
Windows wont start up when computer is turned on, at the bottom of the screen, it just says press f for set up or tab for bios memo, then the screen will be blank with just a cursor blinking
If you are interested in solving the problem more easily and quickly. I think you can try this computer boot up suite, a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all.
Jun 25, 2011 | ASUS Eee PC 1000H Laptop
Computers & Internet Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
