Question about Manfrotto BOGEN 804RC2 Basic Pan Tilt Head with Quick Release Tripod
Can this be used as a steady cam - Manfrotto BOGEN 804RC2 Basic Pan Tilt Head with Quick Release Tripod
  • 685 Answers
I have used a tripod as a steady cam by just extending the legs straight down, but using it like a pendulam. Works ok.
Posted on Jul 15, 2014
2004 ford f150 5.4 3v idles rough but clears when rev engine up
Does you f 150 have electronic throttle control ? An does it have Variable Cam Timing (VCT) - if it does have Variable Cam Timing (VCT) it doesn't have an EGR valve ! What type scan tool did you use to pull the code with ? My FORD factory service information does not show that code for A 2004 F - 150 5.4 L 3 valve engine !
Aug 29, 2015 | Ford Cars & Trucks
I drive a chevrolet aveo 2005 model hatchback. The problem with the car is the revs are not steady and the will not hold. It switches off everytime breaks are applied and it burns fuel really fast.
A crank position sensor is an electronic device used in an internal combustion engine to monitor the position or rotational speed of the crankshaft. This information is used by engine management systems to control ignition system timing and other engine parameters Crankshaft position sensor
Jan 31, 2014 | Vehicle Parts & Accessories
What does a P0316 mean on Ford freestar
P0316 means misfire on the first 1,000 revolution, this is not a random misfire,or a steady misfire, it just means it there Ford has recently moved the misfire from 14000. to 1,000. It can mean the crank and cam synchonizer, a worn COP (coil on plug) COP would give a steady and exact misfire. the cranksensor itself or the harness.
Mar 28, 2012 | 2005 Ford Freestar
Can a faulty cam position sensor cause a car to not fire when it warms up
No. A bad cam sensor usually causes a long crank before firing and a check engine light on steady with a code 41.
Jun 28, 2010 | 1992 Buick Park Avenue
Random misfire on all cyliner a po300 code pops up in the scanner...
It sounds like the coil is breaking down or the cam sensor may be at fault for the misfiring. Use an inline tester and connect from the coil tower to the spark plug wire to check for a good steady fire. Do this on all coil wires to spark plugs. The best time to do this is at night so you can see it fire. You may want to remove the spark plugs and inspect them for a fouling condition. If all is well then look at the cam sensor for the problem. Hope this will help you.
May 20, 2010 | Cars & Trucks
Replacing cams and cam chain .Replacing the cam and cam chain is not so much the problem as lining up the cams for the timing.Any tips on how to keep cam and crank from moving while lining up the cams?
can be tuff-u kinda need 2 people--on my 81 250 I would hold the crank/alt area at the nut with a ratchet-then with my rite hand ratchet the cam sprocket slowly keeping the time marks steady
Sep 03, 2009 | 2002 Yamaha YZ 426 F
Pictures are dark
that is a defall in the cam you have to call sony, the lens is having problems with the light comming in the cam.
Dec 18, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
04 axima
Yes this could be caused by the Nissan NATS system. Your keys may need to be initilized for the car. Is the SECURITY light on steady, or is it flashing?? Check it. If its steady, than the NATS locked you out and you will not start the car. If its flashing, than NATS should be all set and the car should start. MAke sure, that you are using initilized keys.
Aug 05, 2008 | 2004 Nissan Maxima
Manfrotto BOGEN 804RC2 Basic Pan Tilt Head with Quick Release Tripod Logo
69 people viewed this question
Top Manfrotto Photography Experts
JP Services
JP Services
Tom Chichester
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
