How do i wipe all the information out from a nokia 6085 and return it to the factory settings. Is there a master reset code that will clear all the information from the device so that I can restore all the information back into the device so that it will work properly?
unlockjournal.comhttps://unlockjournal.com > Nokia
Method 2: Hard Reset/Factory Reset Using Master Reset Code (One) ... Step 1: Grab your Nokia 6280. Step 2: Now, dial the code *2767*3855#. Step 3: After dialing ...
Nokia Factory Reset It is possible to reset your Nokia to factory settings (Note that you will lose all your data). For this look in the manual of your phone. Soft Reset Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones. Hard Reset It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset Enter the code: *#7370# and press Yes to confirm initialization. Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc) To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons: on/off + * + 3 Before making a Hard reset better backup all your important information: contacts, memo...etc
To reset your Nokia 6085 phone, do any of these depending on what you want exactly either to partial formatting or complete formating. 1. To do partial format, Reset to factory defaults,Dial this code (*#7780#) ,that is Restores settings but preserves user data (photos, 3rd party apps etc)
2. To do a full reset, type this on your phone(*#7370#) : This re-formats completely the C: drive (phone memory). All applications and files stored on this drive will be lost and clean default files will be rewritten. To do a Hard reset, 1. Switch off the phone. 2. Hold down the following three buttons: Green (the call answer button), * button, and '3' button. 3. While holding these buttons, hold the power button for a second to switch on the phone. 4. Release when the phone shows the nokia hands logo or shows other signs of life like the language selection screen. It may take a few attempts and very flexible fingers!
You can't hard-reset it on your own, that can only be done by a Nokia Care Center by flashing the firmware again on the phone.
The phone itself only offers a "soft" reset which only resets the settings.
if you mean a master reset (back to factory settings)
From the stand by screen, select Menu by pressing directly in on the navigation pad.
Scroll to Settings, and select by pressing directly in on the navigation pad.
Scroll to Restore Factory Settings, and select by pressing directly in on the navigation pad.
Enter current Security code and select OK by pressing directly in on the navigation pad.
NOTE: Default Security Code is 12345.
You have the option of using Master Reset or Master Clear to reset settings, and remove information. Master Reset resets all settings on device to factory default. Master Clear resets all settings to factory default, plus clears all data from the device including: PIM data, Call History, Settings, etc. To perform a Master Reset or Master Clear:
Press Start.
Scroll to and select SystemTools.
Scroll to and select either MasterReset or MasterClear.
