Power cord is working, but computer will not come on and battery does not charge. this is on Dell Inspiron 1545 just over 1 year old.
    Master:
  • 635 Answers
Remove the battery and charger.
Hold down the power button for 20sec.
Now plug only the charger and try to turn on the computer.
If it turns on, Update the BIOS. If it doesnt, check whether the adapter is warming up. If it is, it can be an issue with the computer.
Posted on Sep 27, 2010
    Sergeant:
    Champion:
  • 214 Answers
You can simply remove the battery and connect the Power cord. Switch ON the laptop it should be working now.
Try after some time to connect the battery, If still its not working then you need to purchase a new battery.
Battery wont charge dell inspiron 1545
Buy a replacement cord\charger at a computer store or online, make sure the power specs match. If you are refering to the AC power plug JACK in your computer, similar to this:http://www.parts-people.com/index.php?action=item&id=9377&gclid=ciw47k7sulmcfqufnqodreeaew. I would take it to a Qualified Computer tech, or send it to the manufactor, Dell in you case. Unless you have the tools and expertise. It can be done but are you comfortable doing it?
Nov 04, 2012 | Dell Inspiron 1545 Notebook
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
I have a dell inspiron 1545 laptop. Just recently I have been getting a message that the computer does not recognize the power source when I have the AC cord plugged in. We have been using this AC power...
If you are using a Genuine Dell charger, the battery should charge. I don't think its the battery however. My guess would be that there is damage to the inner pin of the charger jack, or possibly damage to the socket where it fits. It could also be down to worn contacts. The charger will power the laptop, as long as there is sufficient contact on the + (inner pin) and a tight enough fit on the outer (-) contact.
If you look closely at the inner pin on the charger, check and see if the inner pin has snapped.
The best check is to obtain or borrow a known good dell charger (aftermarket ones will simply not charge the battery) and see if that resolves the problem, or if you know anyone with the same model, ask them to see if their laptop will charge the battery. That at least will either confirm or deny the fault being with the charger or battery.
More serious is the possibility that the charging circuit has failed. On occasions, the small fuse on the motherboard can fail, or, there is a more deep seated problem on the charging circuit.
Jun 19, 2011 | Dell Inspiron 1545 Notebook
Ac power supply/converter does not charge battery or run computer. Converter is working correctly. Attempts to start are met with 4-flash repeating sequence and off.
Try taking the battery out and working with just the power cord. If it still does not work, even with a known good power cord, then either the power jack on the laptop is bad, the motherboard is bad, or the memory could be bad.
Apr 08, 2011 | Dell Inspiron 1545 Notebook
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Bought a new battery for Dell Inspiron 1545 and it's not charging.
You may want to try a new power cord to verify the power jack on the laptop is okay. If you have a battery plus store; or something in your area. They may test it for free.
Sep 21, 2010 | Dell Inspiron 1525 Notebook
My dell 1545 inspiron wont operate on the battery works fine on charger and battery icon shows 100% and charging but as soon as power removed laptop immediately powers down. physically measured battery...
I think that if it's 100% it should say that it's fully charged.There could be something wrong there.
My computer blinks with a red icon on the printer saying that the it's recommended the battery be replaced when the battery goes bad. It shows 100% charge as well.
I just got a 9 cell battery off of Ebay for my Acer Aspire that lasts 3 or 4 hours and is a little big, but fits the contacts and locks on.
Jul 19, 2010 | Dell Inspiron 1545 Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1545 power adapter not charging machine
if it is under warranty please take it to the service center if you try doing anything by yourself that may damage the warranty and it may pinch your pocket,
Aug 08, 2009 | Dell Computers & Internet
Dell Inspiron flashing amber power light, not charging
I would think the batteries need replacing. That happened to my Dell Latitude CPI. The batteries won't charge past about 3%, so I got new ones and that did the trick. If this is under a year old I would contact Dell about it, if it is under a year old they should replace the batteries.
Hope this helps.
Feb 23, 2009 | Dell Dimension 8400 power supply ** FREE...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
