Question about Mitsubishi VS-45605 50" Rear Projection Television
Mitsubishi vs 45605 no picture
I think the tuner on the set is out , no picture or sound ,but I can play DVDs or other video source .. I checked the cable and it works with other tvs.. If the tuner is out can I use my Denon receiver as the tuner to the VS 45605 rather than replacing the tuner? Thanks R.D.
  • 70 Answers
Yes if the tuner is out and you want to save some money then running an external set top box or your denon are fine. more often than not you will also have better picture quality.
Posted on Jul 09, 2008
Have sound but not picture
Need to know if set had any symptoms before it lost pic. These sets use a protect cir. IF it lost Vert sweep it will shut down the pic. IT was a common issue Mitsubishi used a kit to repair . IT is called the ic401 kit.
Feb 18, 2011 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 rear projection tv
If the green light is not lighting up, you will need to check out the standby power supply inside the TV set, or if this set has a DM board, you will need to change the capacitors. Good Luck
Jul 13, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-55609: No video/audio - just static
You are on the right track. If you cannot see a picture on either antanna A or B then the tuner is suspect.
You may try hooking the cable straight into the TV if you are using a cable box, if not then you should be getting a picture when your other video devices are turned off.
The fact that you get a picture on video tells me that the AV circuits are fine.
Thanks
asnowman
Jul 25, 2010 | Mitsubishi WS-55809 55" Rear Projection...
I have a mitsu VS-45605 and it seems that all 4 main colors have split. is my tv toast?
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Mitsubishi VS-45605 50" Rear Projection...
Completely black screen but has sound.
you probabily need to change the input, find the input button, when you hit it you should get a box on the screen, with inputs, highlight diferent ones and hit select- untill you get pick back, thats what my sugestion would be
Jan 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-45605 with wavy lines
The first things to check are the filter caps in the main power supply area. Usually this rolling is caused by 60 cycle hum coming from the wall. Try that first and update this with your results. Also, while you are in there, resolder any joints that appear grainy or have rings.
Dan
Sep 23, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-45605
G'day mate
To all accounts it does, this can be checked by verifying that it has TWO antenna inputs. To get the PIP working, you will need to split and feed both antenna inputs. Seems to be set up this way to cater to PIP with set top boxes/convertors that have RF outputs
the 2 tuners can be spotted as the shielded assemblies with covers either side in the lower right corner of this pic. There is a mod floating around that involves bypassing the PIP to fix a fault that the set develops. This may have been done to your already.
check here for details.
Hope this helps you. A fixya rating is a great thankyou for my efforts to assist you . Cheers
regards
robotek
Sep 14, 2008 | Mitsubishi VS-45605 50" Rear Projection...
No Picture on Mitsubishi v45605 rear projection tv
If it works the way you have it setup now, leave that way. Plug all your video sources to the denon if possible and leave it that way.
If the denon has the feature to change channels like a cable converter then you can use it or if you still have a VCR you can also use it as a tuner just to tune the cable channels and use the audio/video outputs from it to the TV or denon receiver.
The tuner might not even be available anymore and if it's, is expensive.
Good Luck.
May 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source
Jul 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Sound no picture
You can buy a PIP circuit card on the internet(about $15.00) that can replace your current PIP card. It will bypass the PIP function which is most likely the problem. Instructions for instal come with new card. It's a relatvely easy task if you are in anyway technically capable. Worth the try. Rexman
Apr 05, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
150 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
