Question about Maytag Atlantis MAV6000 Top Load Washer
Motor for water removal does not shut off when in wash and spin cycle.
  • jacobson_bil Sep 27, 2010
    It is Model MAV6257AWW. It sounds like the pump keeps running (makes a lot of noise) but the water does stay in the tub during wash cycle.
    Solution was spot on. Detailed solution helped me replace the pump assembly and even gave me the part #. Found the part locally and it saved me quite a bit of time trying to figure it out.
    Thank you, much worth the $12.00.
    President:
  • 1,554 Answers
It looks like you are referring to a machine with model number other than the model number (MAV600) where you posted your problem because this model does not have a separate motor for water removal (pump motor). The drain pump does not have a pump motor and the pump is also driven by the drive motor . A single belt is used to drive both the drive pulley and the pump pulley.
Explicitly indicate the complete and exact model number of the dryer for specific troubleshooting advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting a solution will not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 27, 2010
  • Jahn27
    Jahn27 Sep 27, 2010
    It sounds like like the pump impeller is broken or restricted and it is where the noise coming from. It seems to run forever because with the impeller broken or restricted, water is not pumped out as manifested by the water staying in the tub and the pressure switch cannot reset to the empty position for the drive motor to stop and hence and hence the pump. Both the pump and the drive pulley are driven at the same time by the drive motor.
    Disconnect power then remove the front panel to access and remove or replace the pump. Insert a putty knife blade or any thin-bladed tool between the front panel and the top cover at about three inches from each corner. Press the blade against the wire clips one at a time while lifting the top cover to disengage them then lift the top cover up to a stationary position. Push the top cover down into the front panel to reengage the clips when reinstalling.
    Remove the screws securing the front panel to the upper front corner braces of the cabinet. Tilt the front panel top away from the cabinet then lift to disengage the bottom from the base clips. Simply reverse these procedures when reinstalling the front panel.
    The pump is located on the right front corner of the machine base. Detach the pump inlet and outlet hoses then remove the three screws mounting the pump to the machine base. Slide the pump to the rear to disengage the belt from the pump pulley and remove the pump.
    Check the pump pulley and clear it for debris that might block water to be pumped out. The pump assembly can be disassembled by removing the four screws securing the pump housing to the pump base and lift off the housing. The pump impeller can be taken off by removing the securing screw and prying it off the spline. Replace the pump if the impeller is broken or if the noise is persistent. Place one hand through the pump opening and lift the belt. Set the pump pulley into the opening then place the belt on. Install the pump mounting screws while holding tension on the belt to keep it on the pulley. The pump assembly is part number 35-6780.
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Oct 30, 2013 | Beko Washing Machines
Maytag Atlantis Model 8551AWW washing machine...fills up with water...then starts the agitation cycle and will agitate for about 1 minute...then shuts off...after about five minutes the agitation cycle...
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Maytag Atlantis MAV8551 Top Load Washer
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
363 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
