Question about Maytag PGR5710 Performa Gas Kitchen Range
I turn the oven on but smells like gas the pilot light glows but know flames come out of the tube. it use to take a while for the flames to lite up but it smells like gas.
  • 205 Answers
Hello- You will need to replace the Ignitor. This problem is a common issue with gas ranges and any appliance repair company should be able to help you and have the part. Best regards.
Posted on Sep 27, 2010
My galaxy range model 790.60012604. The oven do not heat up . The element is lite up but the oven burner do not flame up which leaves a gas smell.
You need a new igniter, it may glow, but is probably not drawing the exact amperage required to open the gas valve decisively... You should also check burner tube and orifice for spider webs or other obstructions... Kenmore Range Stove Oven Igniter 316489402
Jul 05, 2016 | Galaxy Kitchen Ranges
How do I know if the pilot is lit on my heater? Can I light it myself?
Hello
You should be able to see it.There is a small flame in the bottom of the fire box at the end of the gas line tube inside the heater.
Also the gas valve will be turned to on.There are 3 positons on the gas valve, off pilot and on.
If the pilot lite is not lit the valve will be in the pilot or off positon.Plus if it were on and not lit you will smell gas.
Yes you can lite it.Follow instructions on side of heater on how to lite pilot.
May 10, 2011 | Heating & Cooling
Can light the oven pilot light but it won't stay on when I turn the dial to oven temperature. I cleaned the oven prior to this problem with spray on oven cleaner.
I have a 2003 maytag performa stove and i turn the oven on but sometimes it takes a while to come on and smells like gas so and lately i cant get the flames going. i see that the pilot glows but still know flame coming from tubes.
Sep 27, 2010 | Ovens
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
Kenmore oven about 8ys old. The top works fine. When i turn the oven on the glow from the pilot light is visble. then nothing except strong smell of gas. Help. thanks Michelle
The glowbar ignitor has gotten too weak to light the gas.
Replace the ignitor.
Unplug the range.
Turn off the gas ****.
Remove the oven racks.
Remove the bottom oven pan.
Remove the flame spreader grate.
Remove the ignitor and replace it.
Make sure the new ignitor is wired correctly.
Aug 09, 2010 | Kenmore Kitchen Ranges
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
I have a Maytag gas over/stove, Model number MGR5755QDW. The broiler heats, but the oven does not. What are the possible causes and how do I troubleshoot?
If you are having problems with the oven, the first thing to do is figure out if you have a pilot light system or a glow bar system.
Problems with the pilot light system.....The flame has gone out, re-light the pilot. The pilot flame will not light - possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's a internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Problems with the glow bar system.....You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works -click here.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Jan 26, 2010 | Kitchen Ranges
Oven does not turn on! I can smell the gas, I think the pilot flame went off, and I don't know how to turn it on!
looking at the photo / this is a pilot model / the smell of gas is the pilot light in the oven. you wll find it in the center at the back / pull the pot & PAN drawer out to light it . mm
Nov 24, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven is not working - I think the pilot is out but how do I light it?
HI, This oven has an electric ignitor not a pilot. Turn the oven on and look inside the oven. If you see an orange glow, the flame should light.
If there is a glow and no flame, the ignoitor should be changed.
If you remove the floor panel in the oven, you can see the ignitor and test it to see if it is getting 120V.
If it is getting voltage but not glowing, the ignitor will need changed.
I hope this helps you. Please let me know if I can assist you further
Vic
Jun 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag PGR5710 Performa Gas Kitchen Range Logo
191 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
