Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
I had my camer in a bag in the bag I had a bottle (qt) of pepsi.The cap came off the camera got soaked with soda. Needless to say a lot of syrup in the camera. When I got the camera out of the bag the lens were opened- battery dead-new battery didn't work. Can this camera be repaired since it probably got shorted.
  • abie476 Sep 27, 2010
    Well you figured it right I strongly presumed that I should throw it away and get another. Too bad it took good pictures. Best camer ever had. Thanks for confirming what I thought. The $6 was worth to confirm what I knew.
    Thanks
    bye.
  • 10,515 Answers
To begin with, this is an internal fault as you might have observed. Repair would not make any real sense as the cost of repair in this case would be more than $100 which is not worth the cost of the product. In case, if you have electronics repair experience, would be able to read schematics and could keep precautions, i could tell you where you could buy a service manual and provide you few pointers that might help you to fix the camera. Unless, the other option would be to pull out the battery and keep it in dry for few hours and see, if that works.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 27, 2010
  • taran_2005
    taran_2005 Sep 27, 2010
    Thanks for your response!!
    You are welcome.
    I wish i had a better solution, but it's better to be honest .
    Do accept the solution,if 100% satisfied from my response and close the thread.
    Hope i helped you.
How do I remove the soda bottle cap, from the drive shaft end of a 2004 Saturn Vue V6 AWD, in order to remove the yoke, when replacing the carrier bearing.
Can you post a picture of this "bottle cap".. I think you are just seeing the splines (they can kinda resemble the rough crimpings' that a bottle cap has...
There should be nothing on top / on the end of the Midship splined stub shaft... You remove the hog-ring, and press the yoke off/over the spline. the spline and end yoke have a "dead spot" - which makes you keep the driveshaft in-phase during reassembly.. the dead spot is 2 splines that have been joined together at the end.. the end yoke will have a spline removed to accommodate this...
PS - soak the end yoke and spline liberally with PB Blaster.. Walk away..the longer the better... Then attempt to remove.. Good Luck!
Dec 01, 2016 | Saturn Cars & Trucks
Burnt on food on Corning Ware
Soak in hot water and baking soda overnight. Then scrub vigorously with a stainless steel scrubber or steel wool until clean.
Apr 19, 2014 | Corning Ware Wildflower 1 Qt Casserole...
Pepsi machine repair
It is not pc based like newer ones, no reset. A part needs repaired or replaced. Unplugging it is the closest thing to reset.
Apr 14, 2014 | Refrigerators
Spilled soda on a digital camera and now it won't take pictures. What can I do?
Most likely the some of the camera's electronics has been damaged.
The cost of repair may be a little less than a new camera. You can ask for a quote but they may charge for a quote unless you go ahead with the repair.
I recommend you put your money towards a new camera which most likely be better and may have more features that your old camers.
If the SD memory card is OK then you can use it as an addition memory card in the new camers.
Jan 21, 2012 | Sony Cameras
Ny camera was soaked when a bottle of soda wasn't closed properly in my bag so now it powers on but the screen is black what should i do
take out batteries and place camera on the top of hot water system,and leave ther overnight,facing screen up to your ceiling,sitting on flat part of hot water system ,make sure all access soda is wiped off,this will take mositure out,try hot water system first before thinking the worst,this is a way to see if there is damage internal of device.
May 06, 2011 | Sony Cameras
Okay i got pepsi in my camera, so now when i put batteries in the green light turnson and stays on but nothing is displayed on the lcd.
There is nothing you can do. You've just got a sugary acidic liquid into your camera which has presumably partially dried by now.
Even if you could remove the sugar residues (difficult:you'd have to soak parts the camera in distilled water) there will still be residual damage caused by carbonic acid, and this will continue to corrode the camera circuitry for months. If you've used a sugar-free Pepsi variety, then there will be no sugar residue but the acid will still be present.
Sorry, but your camera is a write-off. Even a professional repairer would refuse to attempt fixing your camera: the cost would exceed the camera's value and the ongoing internal corrosion would make it likely what you'd soon return for warranty work which would make no money for the repairer.
There's only one thing you can try. Soak it it Coca-Cola...'Cos "Coca-Cola Adds Life".
That last bit WAS a joke...
Feb 07, 2010 | Samsung SL30 Digital Camera
VENDO PEPSI 407 soda machine
selection number 7 reads sold out but its full i have a vendo drink machine that is electronic and i push the code button to test then select number 7 vend on first button then third button to test vend and it showed an error failed .what else could i try i need some sujestions. please.
Apr 23, 2009 | Refrigerators
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
