Question about Amana Dryers
We have an Amana LE9207W2. We start the dryer and within minutes it stops with an error code of SH. Do have to tell you that the dryer would seem to get overheated and shut down. That had been happening for quite a while. We would let it cool down in between loads and it would continue on. Just recently we started getting the SH code and a long beep. It's just progressively getting worse.
  • 205 Answers
Hello- The error code is for an "Open Thermistor". You will need to have a Tech out to replace it. The part is about $30. As well, take a look behind the dryer and see if the flexible vent has been crimped or crushed and if so replace it. You can get this 4" ducting at most hardware stores. Also check the air flow on the exterior of the house where the dryer vents to. You should be able to feel a good amount of air coming out when the dryer is running. If little air is coming out and the ducting runs a good distance through the wall you should have a duct cleaning service out to clean it. Any issues with the venting of the hot air can cause problems with the thermostats and thermistor as well. Hope this helps, best regards.
Posted on Sep 27, 2010
P5H code on an amana oven
This is actually the 'PSH' error code which stands for 'Push To Start'. If you do not press the start button within five seconds of a command that will display telling you, that you forgot to PUSH the Start button. If it is randomly showing up by itself you have a defective touch-pad
Oct 21, 2016 | Amana Kitchen Ranges
What does p5h code on an amana oven
Start for just 1/3 second then stop with error PF ?
Hey Andy, thank you for your post!
From what you have described your Frigidaire dryer, GLEQ2152ES, is running for a few seconds and then displaying an error code of "PF". The error code of "PF" means there is a power failure and this could be an issue within your control panel or power source. I would suggest performing a reset, this could help clear our any miscommunications within the panel, and you can do this by disconnecting the power cord for at least ten minutes. I hope that this information is helpful towards your repair. -Matt
Feb 17, 2016 | Frigidaire GLEQ2152ES Electric Dryer
What does error code 1 stand for?
did you get this dryer because the last one stopped working check the dryer vent it may need replaced un hock it from the vent pipe and try it then it sounds like it has a vent problem try it telling the machine to stop so it won't burn up the coils or sensor let us know if
that was what was wrong thanks and good luck!
Jun 20, 2014 | Kenmore 63942 Dryer
Frigidaire Gallery model GLEQ2170KSO dryer turns off within a minute.
Hello allisonarena - Try reprogramming the dryer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn on the unit. If issue persists, then the dryer may possibly be experiencing more serious issues such as; wiring failure, faulty control board, thermal limiter, or defective door switch. I would recommend connecting with an experienced appliance repair tech to assist further and to reduce the risk of unnecessary parts.
Jun 12, 2013 | Frigidaire Dryers
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
Have an Amana dryer LE9207W2, when you push start nothing happens, the screen is on showing auto drying and clean filter is blinking, we have cleaned the filter tray and even have taken the mounted tray...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 19, 2011 | Dryers
My dryer will start and run for about 5 minutes than stop with code HE what should we do did everything stated in manual
Look in your owner's manual to find out what the code is trying to tell you is wrong; then get back to us.
Jim Hart
Jun 14, 2010 | Amana NED7200TW Electric Dryer
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
Dryers Logo
192 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
