Question about Daewoo Washing Machines
I have a daewoo automatic washing machine DWF 1168 pb. I had to inclinate it 90ยบ to change a broken hose it had. Now the internal barrel is jumping out of control. Coul you please help me?
  • 1294 Answers
SOURCE: daewoo dwf-6094r wont spin on spin cycle
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
And rate me pl, if the solution has worked......
Posted on Dec 02, 2007
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
Posted on Jun 10, 2008
masteria
  • 355 Answers
SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Posted on Jun 16, 2009
  • 215 Answers
SOURCE: Water overflowing during use
Seems like blockage in pressure system, machine will always think it is empty if so. Pressure system is under the lid, a round switch with a thin pipe going to it. At bottom of this pipe it is probably blocked with limescale or residue from detergent.
Posted on Feb 12, 2010
ZJLimited
  • 17970 Answers
SOURCE: LE CODE WHAT MEANS. DAEWOO
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Posted on Apr 21, 2011
Can you repair automatic daewoo washing machine?
we here at fixya do not NO SHOP . try a local repair service
Oct 02, 2016 | Daewoo Washing Machines
I have daewoo dwf 200 le and it not taking the water from the pipe outlet what to do to fix the problem
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
Aug 17, 2014 | Daewoo Washing Machines
Why wont My Daewoo DWF-750 washing machine not empty water automatically
You've probably got some debris in the pump, or blocking the pump inlet. If you can do this without making a mess (or shocking yourself,) try backflushing the drain hose.
May 06, 2014 | Microwave Ovens
Daewoo DWF 806 MF does not hold water
if the drain hose gets too far down the drain ,it can get into the water that stays in the trap and cause it siphon out of the washer.try pulling it back up about three inches and zip tie it off to one of the fill hoses,
Mar 15, 2014 | Washing Machines
Daewoo washer DWF 800WPS water drains before wash
Make sure the drain hose is about 1 metre high from ground. If drain hose is lower the water will keep draining.
May 27, 2013 | Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
What is LE error for Washing Machine Daewoo DWF 772W model? how to solve it?
Good Luck!
Jun 16, 2009 | Washing Machines
Washing Machines Logo
133 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
