Question about A.O. Smith Plumbing
I have a A O Smith shallow well pump ACE5S and am having difficulty priming it. I do not see a fill plug on the pump itself. What am I looking for and how do i exactly prime the system?
  • 104 Answers
SOURCE: Flotec Shallow Well Jet Pump won't pump water
The tank is an air tank, it works like a cushon and accumulator.
Have you reconnceted the pump? If not fill the pipe that goes to the well with water. It should not drain down, there should be a foot valve that prevents the water from running back into the well. So if the foot valve is working it should not take a lot of water to do this.
Pour water into the suction side of the pump until the pump is as full as you can get it, reconnect the pump and start it up. Yes it does need to be primed
Good luck
Posted on Mar 17, 2009
  • 10 Answers
SOURCE: jet pump does not pump water
I had a similar problem and as a last resort took the pump apart and cleaned it and the jet. It's a very old pump but works ok now.
Posted on Oct 24, 2009
  • 523 Answers
SOURCE: My well pump keeps losing its prime. The pump
There may be a slight leak within the suction piping, just enough to allow air to enter as its sits for an extended time. I'd be ceratin the foot valve is good and check over all of my suction pipe connections.
I hope this may have helped,
Tom
Posted on Oct 30, 2009
  • 126 Answers
SOURCE: Shallow Water Jet pump will not start
on the pressure switch are the points closed if not its not asking for water.that flat plat under the two screws with springs on them,push down on the plate that will close the points then figure out why its not closing
Posted on May 17, 2010
Testimonial: "That was exactly the problem, the pressure switch had to be replaced and it now works fine"
txpipelayer
  • 20 Answers
SOURCE: shallow well pump every two
You should have a check valve installed on the incoming water line ( suction line) of the pump. This should keep the water from leavin the pump. if you still need to prime then there is a leak on the incoming line from the ground to the pump and you will need to have a well company come out and install a new line.
Posted on Sep 16, 2010
CANNOT GET NEW PUMP TO PRIME,OLD PUMP WAS WORKING FINE JUST LEAKING AROUND MOTOR/PUMP HOUSING,BEST WAY TO PRIME NEW PUMP IS MY QUESTION
A shallow well pump needs to be primed. On the bottom of the well above the sandpoint there should be a foot valve (check valve) installed.
On the top of the pump there is a fill cap. Fill the pump until it is filled to the top. I
Replace the fill cap and start the pump. If there is air remaining in the well attempt a second time.
If the pump can not be filled it would indicate that the check valve is not working\ or the water level in the well is low.
cannot-get-new-pump-prime-old-pump-edcyhy51ohkznhh1wg1ly0d0-3-2.jpg Hope this helps?
May 17, 2016 | Utilitech 1-HP Cast Iron Shallow Well Jet...
How to prime an A O Smith pool pump
if the pump is higher than the pool, you should have a ball valve at the front of the pump. close this valve, fill pump housing with water. close the system, open the valve and turn on pump. if the pump is below the pool level, you shouldnt have this problem.
Jun 27, 2014 | AO Smith Pool & Spa
Priming shallow well pump
You need to remove the prime plug and fill it with water. If it does not fill there is a leak in the llines going to the foot valve or the foot valve is leaking.
Jan 11, 2014 | Flotec Plumbing
I have a Mastercraft1/2 HP self priming Shallow well jet water pump, the water fell below the intake in my well and I quickly noticed and turned off the pump. We had water delivered and I'm not su
If water is back up above the intake, it should prime itself in a few minutes. As long as you don't let the case get hot to the touch it should be okay to run dry.
If it fails to prime and pump up pressure, you may have to prime it.
Oct 20, 2012 | Plumbing
Prime the pump
see the FIRST in red under the STA-RITEremove the lid fill the pump up with about 3 gallons of water then replace the lid and start the pump. should start to flow in about 1 minute, if not repeat priming procedure
Jul 19, 2012 | Sta Rite Industries Shallow Well Jet...
1 hp water well pump hums but willnot start shaft to well is free
You may have an air lock/bubble. Try priming the pump with water before you switch on the pump.
Feb 29, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
I have an A. O. Smith 1/2 hp. deep well pump. I want to change this pump to a shallow well pump. ( from tow lines to one ) Where can I get the part that I need.
you can do this one or two ways. look up an A O Smith pump dealer, not a plumbing supply house or contact A O Smith direct.
Sep 07, 2011 | Plumbing
Pump does not pump anything. motor is running and getting hot, no water being pumped. i have to prime this stupid thing?
If you are trying to draw water from a lower place, you may have lost prime. It is also possible there is a reason for this loss of prime, maybe a leak on the suction piping. Remove some fitting on or near the discharge of the pump, fill the body completely with water. If it goes in, fill the entire suction piping with water, too. Open a faucet nearby, turn on the pump and wait up to 5 minutes. It should spit and sputter, sound will change, some water will discharge, but eventually, you should get steady flow.
If you lose prime again, look for leaks in the suction piping from the inlet of the pump to where the piping goes into the ground.
Your FixYa Texpert,
Gary
Aug 16, 2011 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
54 people viewed this question
Top A.O. Smith Plumbing Experts
Donni Steen
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
