Question about GE Washing Machines
Eterna series washer clutch replacement how to
Need to replace clutch on a Ge ewa2000a0ww. Need overview of procedure.
5 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Posted on Oct 03, 2008
Maytag317
  • 1136 Answers
SOURCE: replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 03, 2009
hiltonjug
  • 612 Answers
SOURCE: I need to replace the clutch and belt in my GE washer
I hope this will help you see what to do.
Please rate this solution if helpful
Posted on Aug 21, 2009
  • 8 Answers
SOURCE: ge eterna series dryer.It gets very hot and shut's
This is most likely one of the thermostats. One is for high temp, one is for low temp. They are both located on the inside of the back wall on the sheet metal rim that the drum fits into. You have to remove the top and front panel, remove the belt and the drum itself (just pull it straight out through the front of the dryer) to access them. Once you remove all that they are in the upper-left corner of the back wall (if you are looking in from the front of the dryer). They are simple to replace, with only one screw holding them in place. I have an Eterna series and I happen to have it all tore apart right now waiting for the rear bearing I ordered to come in and can see them clearly. If you need photos I will be more than happy to email them to you.
The answer above was incorrect about the wiring, there will be two wires to one and four wires to the other. I believe the one with the four wires is the hi-temp thermostat, but double-check that with your local appliance parts house. If you have it that far apart, you might as well replace the bearing ($11 for mine) and the belt cause they will eventually wear out anyway.
Posted on Nov 09, 2009
GE Eterna Series Side by Side refrigerator ice maker stopped making ice
Please try posting this question in the Kitchen Appliances/ Refridgerator and Freezer Accessories section. It is now posted in the Getzen/Eternana musical instruments section. Getzen Eternas are trumpets.
Feb 20, 2014 | Getzen 900S Eterna Classic Series Bb...
GE eterna spacemaker microwave won't heat
The problem is a magnetron, "heart of the system" or the inverter board, "if 7 years old or less" and possibly the keypad control board, all of these items are not cheap and lethal voltages are present.
May 05, 2012 | GE Microwave Ovens
Ge spectra eterna series gas stove broiler will not fire up. The glow plug gets hot, but the broiler fails to start.
I have an GE Spectra Eterna Series where the oven comes on and only gets warms no matter what setting the oven is set at. Can some one solve this problem?
Mar 07, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
Fridge always running
Check the fan which cools the compressor from behind the fridge . If not working , replace the fan motor . ALSO , check to be sure the coils under the fridge are clean of dust (from the front only ) .
Aug 01, 2009 | GE Refrigerators
Will not spin
It sounds like your motor never runs. Check the lid switch.
May 31, 2009 | GE WBSR3140DW Top Load Washer
My GE Eterna washer doesn't spin and smells of
YOU NEED A NEW BELT AND AN ADJUSTMENT
STEVE'S APPLIANCE
516-300-3249
Apr 06, 2009 | GE Washing Machines
Kenmore 70 series is slow to spin
it sounds like you have a bad clutch in the washer. To diagnose this failure, you would need to pull off the washer cabinet and pull the transmission. It is likely that you would find the clutch band glazed over. It is probably not exerting enough torque to release the brake and spin the washer.If you find this problem, you can try sanding the band to rough it up. Reassemble the washer and check for proper spin. If this fixes the problem, you will need to order and replace the clutch band.
This type of procedure is usually performed by a service technician. I don't recommend attempting this repair unless you are completely confident that you can safely perform the work.
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Ligthing the oven glow bar
you need to replace the oven glow bar take out the oven racks in the bottom of the range you will see two screws remove them remove the bottom oven pan under that is the flame spreader shield under that under it you will se the ignighter at the back of the burner bar just follow the instruct sheet with the ignighter to install and reverse just because the old bar glow-es don't mean its good just replace it
Jul 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Washing Machines Logo
204 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
