Question about Vacuums
Belt slipped on my hoover self propelled windtunnel
  • 40 Answers
Please give additional information?
Sometimes belts can be mounted in 2 directions. If installed in the wrong direction, the roller will rotate backwards and the belt can come off. Also, it is possible that the belt has stretched. Verify that the roller spins freely with the belt off. If it doesn't, remove it and clean it and verify that the bearing are good.
Posted on Sep 27, 2010
SOURCE: Hoover Bagless Windtunnel - Self Propel feature not working
I have the same problem with ours. If you lift the vacuum by the handle it breaks the lever on the transmission. You can find a replacement cable and lever on line for about $16.00 it is somewhat involved to repair but can be done by someone with mechanical ability. You can try and find a repair shop but be careful, they sometimes tell you the part is not available and try to sell you something else. I think they should be able to do the job for aprox. $80.00, but they may want more. I did it myself plus the height adj. knob for $24.00
Posted on Nov 25, 2007
SOURCE: Hoover WindTunnel Self-Propelled V Belt
Hi, That is what was happening to my Windtunnel. Until I looked at the little round disk "plastic". there was a crack in it and this puts pressure onto that V belt to make the brush spin. I have a replacement idler arm assy unit which has to be replaced. I hope this helps Cindy G.
Posted on Aug 16, 2008
nwj2468
  • 76 Answers
SOURCE: Hoover Self-propelled WindTunnel U6436-900 cable
the belt could be broken. check the belt for the drive system.
Posted on Apr 19, 2009
SmartAlec
  • 171 Answers
SOURCE: why is self propelled not working on my hoover windtunnel
Hi there SmartAlec from Nelsonvacuums.com.au here. Actually the brush belt needs to be tight as well for the self propell function to work. However once you change that if it is still not working it could be the drive mechanism itself. You can test this by laying the vacuum flat on its belly so you can see the brushes. Turn it on and push the handle down (as if you were actually vacuuming). This should get your drive wheels going they are two wheels about 3 inches away from your brushes. If they are not turning then you need a new drive mechanism. If you are in australia i can get you one through our website above.
Hope this helps. Happy Vacuuming :)
Posted on Sep 03, 2009
  • 18 Answers
SOURCE: hoover windtunnel self-propelled - will not turn on
You probably need the switch replaced. It's fairly simple to do youself, and it is a known problem with these vacuums.
You can order the switch from hoover for about $10
Posted on Oct 08, 2009
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover U6439: Belt keeps slipping off
The belt is stretched and you simply just need to replace it. You can get the belts you need for this model here:
http://www.vacbelts.com/hoover-self-propelled-windtunnel-belt.htm
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How to install the belt on the hoover self propelled vac
Video Repair instructions on installation of Hoover Windtunnel Self-Propelled vacuum ;
If you found the video helpful, please be sure to rate it by clicking the thumbs up icon below. If you have any questions about this repair, please request a clarification below.
Thank you,
Chris
Jul 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
59 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
