Question about ASK Proxima C180 Multimedia Projector
We were using the ask proxima c180 at our church service tonight and it just went out .i noticed that the power button was on but it would not power up. i also noticed a noise coming from it so i unplugged it a number of times. still no change so i brought it home. i took the lamp door off pushed in the door safety switch and i saw the fan start to kick in and the display lights come on and the {wait ?? seconds } come on for a split second then it kicked back out. it continued this sequence. so then i took the lamp out and put it back in to see if this would reset it ,but no luck. can you please help. thanks . tony
  • ASK Proxima Master
  • 17,129 Answers
Looks to me a Lamp failure or a fault inthe Power section.
these two sections are a bit tricky and so it might require a swap to confirm . The lamp can take in more current and shut off the circuit in the process as it happens.
so also the power supply can shut off if there is heavy drain detected which can be the lamp or the failure of the power supply to deliver as required.
Do not buy out the lamp unless you have a spare one with you.
So also check the power supply section for any dry solder or connector links to be loose.make sure the filter are clean and safety switches of doors are closed.
If not get help to swap and test to confirm.
Posted on Sep 27, 2010
Proxima c180.I keep getting bulb striking error.
take the lamp door off and look to see if the socket that the lamp plugs into has been pushed out of place. Very common problem with this model. If this is the case, you will have to remove the top cover and push this back into place so the lamp can plug into it completely. If this is not the case, then your lamp or ballast could be bad.
Aug 18, 2010 | ASK Proxima C180 Multimedia Projector
ASK PROXIMA C180 no power at all
if you take the lamp door off, pay attention to the "peg" on the lamp door to see where it depresses the safety switch. if you look it is a silver metal lever that this peg pushes in. plug the unit in and find something no conductive to push and hold the lever in. while holding the lever in push the power button. if the unit powes up then that means the lamp door has distortion from the heat of the lamp. you can try to find another lamp door, or you can get creative and find a way to meld some more plastic to the length of the "peg".
Jul 06, 2010 | ASK Proxima C180 Multimedia Projector
My ask proxima c180 does not power up. I have confirmed the power cable is firmly inserted. When I press the power button nothing happens
take the lamp door off and manually hold in the safety switch.(if you look at the lamp door and see the post, the post is what pushes the switch in normally) while holding the switch in, push the power button. try the button on the projector and the remote. if the unit powers up it means your lamp door is miss-shapen from the heat from the lamp. if this didn't fix you problem, you need a power supply.
May 27, 2010 | ASK Proxima C180 Multimedia Projector
ASK Proxima C180 Message saying :Lamp Didn't Strike"," Retrying" What can I do to fix this problem
if you know your lamp is good, make sure the connection on the lamp housing and the connector on the lamp itself are actually connected. sometimes when the lamp is installed the connection on the lamp housing is pushed out and the connection is not actually made. you can also reset the lamp hours and see if that works.
Apr 28, 2010 | ASK Proxima C180 Multimedia Projector
Proxima c180 has a rectangular yellow image in the center of the screen. You can see the displayed image through the yellow. The lamp has been replace and no improvement
the polarizer on the blue lcd panel is fried due to excessive dust and heat. you may need to replace the whole optical engine. send it in to an infocus service center for repair. try www.avsolutionsny.com. they're really good.
Jan 26, 2010 | ASK Proxima C180 Multimedia Projector
Ask c180 shows video well but no input on computer 1 & 2 can not show data
reset the settings to factory default and make sure the resolution matches
Jan 22, 2010 | ASK Proxima C180 Multimedia Projector
Fan stopped
it not sensing the fan's movement. there are a few fans in there. did you check them all?
Apr 08, 2008 | ASK Proxima C180 Multimedia Projector
Service menu proxima x350 , ASK M3 or Yokogawa D-1200X
you should be able to by the menu button on the top of the machine.
Jan 26, 2008 | InFocus Proxima UltraLight X350 Multimedia...
ASK Proxima C180 Multimedia Projector Logo
93 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
Lyle Siemens
Lyle Siemens
Steven Wander
Steven Wander
240cpa
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
