Check and clean your fridge door seals as they may be dirty, have perished/not flexible or even crack.
All doors should also close with a positive 'hermetic' feel: check and remove any obstruction.
You can check the firmness of the seal round the door with a thin piece of plastic or cardboard wedge between the seal and door 'frame'.
Hope it helps.
you have a bottom freezer and when the power is out cold cannot get to refrigerator. Top freezers are less likely to have that as cold air falls. In your case the freezer stays colder. If you have an icemaker you could bag or metal pan ice and put in fridge top shelf. Also find supplier for dry ice for extended issues.
