Question about Amana ALG331RAW Gas Dryer
Stopped heating. Had service repair yesterday and he replaced the ignitor. Does not heat again, even though it warmed up briefly after the repairman completed the job. What else could the problem be?
  • 205 Answers
Hello- Have him come back out (AT NO CHARGE) and check the gas valve coils these are probably not opening the valve, thus letting the gas out. It is a common issue and sometimes we, the Techs, need to sit there and watch the ignitor light the gas for a whole cycle. Often it will heat for 30 minutes and then the coils will stop opening the valve when told to by the timer. It is possible that there is a thermostat issue but less likely. Hope this helps, best regards.
Posted on Sep 27, 2010
My dryer is only 1 and half years old no heat?? should it be an igniter on a dryer this young?
Posted on May 04, 2011
I have a Kenmore Elite 110.74082201. It tumbles, but there is no heat. I cleaned the bottom filter and did get some heat briefly. I emptied out the dryer, replaced that load with wet towels. I turned it...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | Kenmore Dryers
It stopped heating. Still runs but is not producing heat which has happened before and heating coil was replaced. I would like a repair manual or diagram of internal part information.
heatman101';
Aug 14, 2011 | Dryers
Our dryer will heat sometimes and then not at all. As much as a week will pass with no heat and all of a sudden the heat comes on for a load. A serviceman replaced a thermostat and a high limit switch and...
heatman101
Jun 24, 2011 | Dryers
My candy tumble dryer has stopped generating any heat. Is it worth repairing . I've been told candy are very difficult to repair
heatman101
May 07, 2011 | Candy Dryers
We have a Fridgidare stove, model #FGF378WCCB. It was working fine, then one morning, the oven stopped heating - it will only warm up to about 125 degrees. Do you think it might be the thermostat? Or...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | Frigidaire Ovens
Dryer heats briefly, then cools down, takes hours to dry
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 13, 2010 | Whirlpool Inglis IP8200 Dryer
My old Kenmore dryer stopped sending hot air. How can I fix it.?
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 17, 2010 | Kenmore Dryers
Dacor PGR 30 oven does not heat
I have had the same miserable experience - replacing the brain, touchpad, expensive parts - for this supposedly high-end appliance.
Have you checked the ignitor bar? See a good explanation of that at http://www.ignitors.com/oven-ignitors/
and also http://www.theignitorstore.com/product/frigidaire_oven_range_igniter_5303935066/range_oven_igniters
Nov 23, 2009 | Dacor Preference PGR30 Gas Kitchen Range
Rheem Criterion Ignitor Issue?
Maybe some trash or water got into the hose from the draft inducer to the proving switch It happens this time of year.
Mar 27, 2009 | Heating & Cooling
Amana ALG331RAW Gas Dryer Logo
438 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
