Question about ASUS P5L-VM 1394 Motherboard
Cannot detect my sata hard drive during POST. I tried to use another sata cable but the same problem. I tried to transfer the hard drive in same mother board unit and it works fine. I tried the 4 slots (i.e sata1,2,3,4) but to no avail. I already reset the bios by removing the battery on the maother board. Please give me another isolation tyoe of solution. thanks a million
    Guru:
  • 1,481 Answers
Try to use another SATA drive in this machine...if this new HD is detected by this machine...
try connect the old HD on another machine....if it cannot be read there...also.... then i am sorry the HD is OUT/dead....
Posted on Sep 27, 2010
My dard disc wont detict
When installing a new hard drive, a PC may not recognize the hard drive. Incorrect cable installations, jumper settings and BIOS settings may cause the computer to be unable to detect your hard drive. Due to the vast differences in hard drive types (IDE versus SATA) and brands, motherboard brands and types, and BIOS types and configurations, please download or acquire your motherboard and hard drive manufacturers' documentation prior to acquiring a hard drive. Make sure that the type of hard drive you plan to purchase is compatible with the motherboard.
Shut down the computer. Unplug all cables and peripheral devices. Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist. Remove the computer's side panel. (Cases vary. Some will require a small Phillips screwdriver for removal and others feature screwless designs. Please see your case manual if you are unsure.) Locate the newly installed hard drive. Check that two cables are running from the hard drive to the motherboard and to the power supply. If you see only one cable or if either of the cables are not securely seated, plug in the appropriate connector(s). Leave the case's side panel off for now. Reconnect the power cable, monitor cable, and keyboard and mouse connections. Restart the computer. Enter your BIOS immediately. (Your BIOS usually alerts you to the key required to adjust settings. If your screen does not show this information or if you are unsure, consult your motherboard manual.) If it is an IDE hard drive, enter the IDE settings. The BIOS should show the hard drive. Configure it as primary or secondary, according to your computer's configuration. (If you have only one drive, set this to primary. Otherwise, set as secondary.) Save your settings, and exit the BIOS. Once you are certain that the the PC is recognizing the hard drive, replace the side panel. Detect a SATA Hard Disk If you have connected a SATA (serial ATA) hard drive to your computer but are not able to access the files on it, then your system may not be detecting the drive correctly. On either a PC or Mac computer, you can manually detect and mount a hard drive that is locally connected. Once properly detected, the drive will become available for file transfer.
Plug the SATA hard drive firmly into your PC computer and ensure that the drive is powered on. Open the Start menu and click on the "Control Panel" icon. Open the "Administrative Tools" folder and double-click on the "Computer Management" icon. Go to the "Disk Management" tool on the left side of the control panel window. This brings up a list of all drives currently connected to your computer. Right-click on the SATA drive that you want your computer to detect and choose "Change Drive Letter and Paths." Click on the "Add" button and then select the drive letter that you want to be assigned to the SATA hard drive. Click "OK" to save the settings and detect the SATA drive. b> Mac Instructions b> Plug the SATA hard drive firmly into your Mac computer and ensure that the drive is powered on. Open a new Finder window and navigate to the "Utilities" folder, which is located in the "Applications" section of the Mac hard drive. Double-click on the "Disk Utility" icon. Highlight the SATA hard drive that you want your computer to detect from the list of connected drives on the left side of the window. Click on the "Mount" button at the top of the window to have the system manually detect the SATA drive. Hope this helps.
Dec 29, 2012 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
I've a Fujitsu MHV2080At like external disk and from some days PC don't recognize Hard disk and this is "dead" , the led's are ok when i connect USB but the head of hard disk don0t...
  1. Serial ATA:  If you have a 3.0 Gbit/sec SATA drive that is not being detected by your 1.5Gb/sec SATA controller, or it causes your system to lock up when connected to a 1.5 Gbit/sec SATA controller, you may need to jumper your 3.0 Gbit/sec SATA drive to the slower speed of 1.5 Gbit/sec for the system to recognize it properly. For further information on changing the jumper setting to slow down your SATA drive's transfer rate, please see Document ID: 193775
    -48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA:  It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used. Please consult Document ID: 196299 for further instructions.
  2. Faulty Hard Drive
    If you have completed the above checks and procedures and the drive is still not properly detected, please attempt to use Seatools for DOS (see the tutorial here) to test the drive.  If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
Sep 19, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
Sonny computer makes beep codes on booting. It also gives red light on the drive icon
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
Jun 17, 2011 | Computers & Internet
I want to connect this hard drive with other computer. What kind of cable shoud be use for data transfer?
Much better if you buy a usb to sata adaptor, all you have to do is plug the usb adaptor from sata hard disk drive to usb port. It will detect as a removable drive and it is very easy to transfer file. It will serve as a external hard drive. Have a nice day!
Jan 03, 2011 | NEC (OP-220-62006) 1.35 GB Hard Drive
My WD2500BEVT beeps (3beeps pause 3 beeps pause) a number of times then sounds like windows recognizes the drive but does not.
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 30, 2010 | Western Digital WD Scorpio Blue WD2500BEVT...
Segate sata 320gb hdd beeping
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
hope this helps
Dec 26, 2010 | Seagate Barracuda 7200.9 300 GB SATA Hard...
Computer will beep and then power off, power supply?
Test your PSU or replace it
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
One bad lead can cause a computer to fail to detect a hard drive,continue on a cycle,fail to boot
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 21, 2010 | Dell (C3760) 305-Watt Power Supply
Windows wont start. dont know how it happened.
press F2 to go to the system setup, then press arrow down to highlight Standard CMOS feature, then press enter. Verify if the hard drive is detected, mostly it is installed in SATA 0 and you should see like a serial no of the Hard drive. If the hard drive is not detected, you might need to reseat the cables of the hard drive inside the computer. Make sure that all the cables at the back of computer is unplugged to be safe. After you reseat the hard drive cable, plug cables at the back of the computer then turn on computer and press F2, verify if the hard drive is detected, if still not, try to swap the connection of the hard drive and the dvd drive of the computer. Plug back the cables and turn on comp and press again F2, this time the the dvd drive should be on the SATA 0 and hard drive should be on the oter SATA port. If the hard drive is still not detected, you need to replace the hard drive, but if the hard drive is detected on the other SATA port and the dvd drive is not detected on SATA 0 then you need to replace the mother board.
Mar 16, 2010 | Dell Inspiron 530 Desktop Computer...
Sata hard drive could not be detected during win xp installation in acer aspire M3600
It could only be a limited number of problems:
1. SATA drive is not connected to the primary port
2. SATA cable is faulty
3. SATA drive is faulty
The most common solution is to move the cable to the primary/first port
Jul 30, 2009 | Acer Computers & Internet
My sata hard hard drive is not detected in linux
Check in your BIOS settings that SATA drives can be seen as "ATA"
Install Linux, and then , after everithing went OK, change BIOS to SATA again.
Aug 04, 2008 | Computers & Internet
ASUS P5L-VM 1394 Motherboard Logo
169 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
