Everytime we put a load of washing on with our LG WD1470FD it completes half the cycle, then it stops and the letters OE comes up on the screen, do you know what it is and how can we fix it?
5 Suggested Answers
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
  • 343 Answers
SOURCE: MY LG 7KG 1405F MODEL IN DOES NOT COMPLETE THE WAS...
OE is drain error, which means that the machine has detected that the water level is not lowering quickly enough...Probable cause is a blocked pump filter...Check via small door at floor level..Unscrew pump cover and clear filter....Remember that all water will drain from this point, so drain machine first...Leaning the machine back can help...Good luck....Nomess
Posted on May 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
tunde007
  • 2382 Answers
SOURCE: My LG washer will not
Hi, the LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
So since you have changed the pump, check the filter to see if it is blocked, and blockage in the drain hose or somewhere else in the system.
Posted on Oct 17, 2010
Whenever it gets to almost the end of the cycle and usually while it is in rinse, the error message OE comes up and it won't drain the water from the tub or go any further
Had same problem last night with my LG WM1814CW but mine didnt get to the end of the cycle, it would fill and start humming when it was supposed to be draining then the OE would appear. We drained the machine through the front door hose, turned the machine on its side and removed the drain pump. Very easy access and very easy to remove the drain pump. There was a half a bobby pin against the impeller and that stopped the turning. Took the bobby pin out and put it all back together. It works like a charm now. Very nice system that LG has.
Nov 30, 2010 | LG WM-2277HW Front Load Washer
Won't drain during cycle, drain motor noise before stopping with OE drain error?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
Sep 03, 2010 | LG WM0642H Front Load
LG Tromm Washing Machine Won't Drain code comes up OE
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Aug 21, 2010 | LG WM-2277HW Front Load Washer
Wont finish the load
heatman101
Jul 21, 2010 | LG WM2701HV Washer
My lg 7KG 1405F model in does not complete the washing cycle stops at rising (oe) is the code
May 20, 2010 | LG WM-1480FHD Front Load Washer
Apr 11, 2009 | LG WM2042 Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
