Question about Cameras
Out of focus
I recenlty bought a used mamiya 7 with a 67 mm lense. It is sharp in the middle of the negatives but the eages out of focus. What could be the problem?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey Paul FB,
One reason this could be happening is if the film pressure plate is set incorrectly. If you are using 120 film you should of course have it set to 120, and if you’re using 220 film you should have it set to 220. If you have the pressure plate set correctly the plate might be broken, and I would have the camera looked at by an authorized service technician. If your subject is in the middle of the frame and the edges of your images are either background or foreground you might just have the aperture set to a large aperture resulting in a shallow depth of field. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 23, 2008
Pentax K2000 DSLR stopped working after using manual K-mount lenses?
Have a look on Pentax Forums as a guest - you may find something there
Oct 17, 2017 | Pentax Cameras
Lenses on K10D do not focus correctly on low f stops eg; f1.4/2.0 but focus well on higher f stops eg f11. On the lower f stops the lenses are back focusing by around 4 to 5 cm. Any help Thanks
Although you think the lens is in focus, when stopped down, I know it is not.
There are enough articles that tell about Depth Of Field, but I give a short explanation.
The DOF from a 50 mm lens on a APS-C camera, when set to f /1,4. when you focus on 1 meter, is just 2 cm when on f /4 you have a totoal of 6 cm and on f /11 it is 11cm. So wen your camera / lens combination has a back focus of about 5 cm, it will come within the 11 cm you get in f /11. Still the picture is not in focus, but you see what you want to see sharp.
I searched through the complete manual, scanned the review on Dpreview and searched the site from Richo, but noting to find about correcting back or front focus. on the K10D. Perhaps, because in the days this camera came on the market, they thought the photographer who uses f /1.4 lenses is used with manual focus.
I'm, not sure, but perhaps someone on the Richo / Pentax service centre can tell you, if they can correct the setting for your lens.
To my experience, the front or back focus is in the camera. (the six or 7 lenses I use on my camera, all have the same back focus, but my Nikon has a setting to correct that.
So if you want to use your lens without any change made to your camera, there is only one option, focus manually.
Sorry I could not find more.
Success
Mar 08, 2014 | Pentax Cameras
Is the Raynox DCR 250 compatible with 75-300mm Canon lens?
Have a look at this page for discussion about this adapter. Depending on the lens you're using it with - the DOF can be extremely shallow and make focusing difficult. If you're in Auto Focus mode - try switching to manual and see if you can get better results.
Aug 21, 2012 | Canon EF 75-300mm f/4-5.6 II Lens
Focusing a mamiya k/l lens.how do i use the floating element ring? thank's
Step A. Set the floating element ring to its' infinity position (if you are using extension tubes, this will vary and you must set according to the tubes).
Step B. Focus the camera on your subject.
Step C. Look at the bellows scale on the camera body (it will generally range from 0-40) Important: Don't read the scale akin to the lens you are using. This will make perfect sense, when you examine the bellows. Mentally record this number.
Step D. Adjust the floating element ring to the recorded number.
Step E. Leave the ring on this new setting and re-focus the camera on your subject.
Step F. Make sure the dark slide is removed and capture your photograph. :)
- That's it mate. Not so foreboding, when you
Dec 12, 2010 | Mamiya K/L 127mm f/3.5 RB Lens
Using auto focus 35-55 mm lens on d40x will not take picture but if I use manual focus, I can take picture.
It is because the lense is only an AF lense. The d40x doesn't have an on-body auto focus motor so that needs to be on the lense. I have a d60 and have the same problems. You can use the manual focus on the AF lenses; however, to use auto focus, you need to buy an AF-S lense. It's disappointing I know, but that's the price we must pay for saving on our body lol
Jul 20, 2010 | Quantaray 135-400mm f/4.5-5.6 for Nikon AF
Will Nikon D300 focus with the 11 point AF11 setting?
You may want to consider fine tuning the lenses. I understand that you want the shallow depth of field, but the lens is sharpest at the middle f stops. What is the comparison between a stationary object like an apple or grape (something with a circular shape). I understand you have a higher shutter speed, but the small movements of a person could cause variances in a single focus mode. Are you using the half-shutter press for focus or the AF-E button? Tripod? Remote shutter release?
I asked about the distance relative to the lens length because the DOF can really change based on this. I have found this recently with my macro work so I wanted to find out if you have experimented with this or fired a bunch of shots at a single setup.
Apr 27, 2009 | Nikon D300 Digital Camera
Manuel lens dos not turn any more
most likely some of the gears are offline or collapsed. when that happens it gets difficult to turn. you could send it to mamiya for an estimate or to mackcam.com
Dec 31, 2008 | Mamiya 35mm f/3.5 Lens 645
Mamiya-sekor C 65mm lense
Any luck with the lens?
Need help?
atdlee@netzero.com
Oct 18, 2007 | Mamiya K/L 65mm f/4 RB Lens
Unsharpness
if you can acquire sharp image with your 80mm, but not the 50mm and 120mmmm, there is no problem with your camera body, i.e. lens-flange to film plane. but how come you can not manage to get a sharp spot anywhere from the full turn of focusing rings with your 50mm and 120mm, unless the lens units inside these 2 lenses shifted. i doubt this happened to both lenses simultaneously?
if you are sure that your lenses have problem, send them for focusing test, since they are good and expensive lenses.
pc-cook
Sep 14, 2006 | Hasselblad 503CW Medium Format Camera
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
