Tochiba laptop wont turn on. 4 months old. I brought a new charger charger light on battery light on. Push on off it flashes and turns straight back of/ any suggestions. Need it for presentation tonight. Tried the 30 seconds but nothing.
  • c_i_designs Sep 27, 2010
    yes it is under warrantee but thought if it was something simple to fix I could use it tonight
  • 31 Answers
Not the best time to try and use a laptop you've been having trouble with. Go to toshiba.com to get their phone number or tech support chat because your laptop should still be under warranty.
Posted on Sep 27, 2010
Vostro 3500 won't turn on and charger light is flashing
How old is your laptop? if it is over 5-6 months it could be because of a faulty battery. You may want to upgrade or change your battery.
Apr 10, 2013 | Dell Vostro Computers & Internet
Acer 5315 wont turn on and wont chare, no lights at all on laptop but charger fully working.if i eventually get it to turn on it turns straight back off
If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Nov 04, 2011 | Acer Aspire 5610-4648 Notebook
My laptop is an Asus 1005HA-V and I'm having trouble turning it on. I've had it for about a year and when I try to turn it on it's lights flash and then turn off again. Also sometimes when it's on the...
Things that you can try:
1. disconnect the charger and the battery. 2. press and hold the power button for 15 secs. w/o the charger and the battery (the reason for that is to drain flea power). 3. connect the laptop straight from the charger w/o the battery and turn it on. It should turn on fine. If nothing happens, the motherboard is bad or the charger.
Jan 17, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
We have a 11 month old elite traveler scooter. The battery will not take a charge. We have had no previous problems. Any suggestions?
I just fixed this problem in a Go Go Elite that was less than 6 months old. We would plug in the charger and the "charge" light would not turn on, just the "power light" I took out the battery pack (check manual for instructions), removed the cover (8 philips head screws) and checked the voltage on the two batteries. One read 4.5 volts and the other 4.7 volts. They should both read at least 11 volts, ideally 12 volts. Evidently the Pride charger will not work if it detects that the batteries are too low. So I took out one battery at a time and connected a 12 volt auto trickle charger to it for 3 hours on each battery. Checked voltages and it brought them back up to 11.5 volts. I reinstalled the battery pack and then connected the Pride charger and THEN it showed a "Charge" light. I left the pride charger on for 12 hours and it brought it up to full charge.
Advice: Don't let your batteries get too low or the factory charger will not work.
May 19, 2010 | Pride Mobility Products Go-Go Elite...
I brought anew battery and new charger for my
We offer all kinds of laptop batteries. such as apple battery ,Asus battery
and so on.
May 14, 2010 | Acer Aspire 3680 Laptop
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Compaq laptop will not power up
try taking the battery out, make sure the ac adaptor is not connected, hold down the power button for 60 secs and then put the battery back in and try turning it on.
Sep 14, 2009 | HP Pavilion dv6000z Notebook
TOSHIBA satelite wont turn on
If you have tried a new power supply and taking out the battery and it still won't start, then the problem is with the power management system on the motherboard. This means that the motherboard will have to be replaced. Check into your warranty, being that it's only 10 months old, it should still be under warranty. If so, then get it to them to be fixed asap, before they decide your warranty doesn't cover it.
Jun 26, 2008 | Toshiba Satellite A135-S4527 Notebook
NV3 Camera - won't turn on or charge
have been having the same problem. Just pulled the lead out straight and stretched it and now it is charging red light on constantly. May have been a kink in the lead?
Jun 24, 2008 | Samsung NV3 Digital Camera
Computers & Internet Logo
David Payne
David Payne
