Question about KitchenAid KGRT607 Gas Kitchen Range
Stovetop ignitor All the burners on the stovetop light when I turn them on except that only one of them conitnues to spark all four burners even after the burner is lit. It didn't do this yesterday.
  • 240 Answers
Not that this will fix it for sure, sometimes it does. Remove the top of the burner that is causing the problem, and take some sand paper and clean the top of the ignitor and the bottom of the burner itself. That will sometime cure the problem. If not, you could have a bad spark module, or a wiring issue.
Posted on Nov 15, 2008
Whirlpool supercapacity 465 gas oven will not heat up all of a sudden
Does the igniter glow white hot? What is the complete model number?
Feb 13, 2013 | Kitchen Ranges
Viking model VGR48 stovetop burners will not ignite?
First shut off the gas supply & disconnect electrical power to the range.
  • Remove all the burner control knobs, grates, burner caps & trim rings.
  • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
  • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
  • Place cardboard between each side of cooktop & bodyside to prevent damage.
  • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
  • Remove the wire from the electrode.
  • Remove the screw from the electrode mounting bracket to release the electrode.
You can replace the electrode & reassemble following instructions in reverse order.
Aug 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 | Cooktops
One stovetop burner does not initiate igniter sparking.
Its most likely the igniter. It might just be dirty, but its easy to install a new one. They are attached by two screws and a single plug. I'd suggest turning the power off to the stove before plugging in a new one.
Feb 14, 2009 | Viking VGSC306-4B Gas Kitchen Range
My tappan oven will not always light
for the top burners you have to get to see the ignitors so that you can see the spark,the spark have to spark like a spark plug in the car, it most be on the tip of the ignitor.if not. the spark it's sparking on the wroung spot,wires may be wet or broken. thats one of the reason, the second one,there is small holes fasing the spark ignition on the burners when grease blocks them, they will not light, you can clean them with a paper clip or a safety pin. for the oven,some ovens do not have the spark sistem, they have the ignitor wich it looks like a small bar about 4 inches long by 1 inch some of them are round. thats the part that needs replacing
Dec 06, 2008 | Kitchen Ranges
Hello, I have a Frigidaire freestanding crown series gas range that has two problems. The most important being that the oven does not light. The stovetop lights, except one burner that you hav to light...
I figured it was the ignitor given the burners work fine and I could smell gas from the oven when I would try to turn it on. So I found a local parts store and bought the replacement ignitor. I cut the wires of the old ignitor close to the ceramic and spliced the new one on with porcelain nuts and voila my oven now works again!
Nov 18, 2008 | Frigidaire Kitchen Ranges
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
One of four dials doesn't spark ignitors...
its a spark switch gone bad, 1 switch will turn on all four burner electrodes(its just easier 1 module)sometimes model dependant you can eplace justone switch, sometimes they come as a complete set
Feb 24, 2008 | GE 30 in.Profile JGP945 Gas Cooktop
KitchenAid KGRT607 Gas Kitchen Range Logo
300 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
