Question about LG LRSC-26922 Side by Side Refrigerator
LG SIDE BY SIDE - REPLACED FILTER BUT WATER VERY SLOW
We have a lg fridge freezer and although it has been rather good there is a problem with the water/ice making machine.... it has always worked fine until it started getting slower and slower. it used to almost gush out but now its more of a trickle.... it was due for a filter change shortly after this problem began and we have changed the filter but it is still slow... any ideas???? thanks kayleigh
  • Stacy Krieger Mar 16, 2009
    I have the same problem. I replaced the filter and the water still comes out as a trickle from the water dispenser and for the ice maker.
  • 489 Answers
You may have ice building up inside the fill tube that is slowing the water flow.  You will have to remove ice maker to see inside the tube.  If the tube has ice buildup, use a hair dryer to melt the ice.  Then is should work fine.
Posted on Jun 08, 2008
LG side by side model# lsc26905tt, won't dispense water. I can hear the pump trying to pull water but the water is sitting in water line just outside of filter on the outside of fridge.
Sounds like the dual solenoid water control vave. Located in the back it will have two wire connectors going to solenoids. They are replaced as a pair and most local appliance dealers have universal replacemants. http://www.lg.com/us/refrigerators/lg-LSC26905TT-side-by-side-refrigerator
May 31, 2015 | LG Refrigerators
Water flow of filter too slow
When was the last time you changed the water filter? If the filter is clogged from long usage it will slow down the water flow. Filters should be changed 6-12 months.
Jul 11, 2010 | LG LFX25971ST Bottom Freezer French Door...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Lg side by side refridgerator ice maker
you can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Dec 10, 2009 | LG LSC27931S Side by Side Refrigerator
Replaced Water Filter - Now Slow Water Dispensed
If its should solved with an original spare part again then there could there be a marketing technical patent on some materials.
Aug 26, 2017 | LG LSC27931S Side by Side Refrigerator
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not...
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Aug 06, 2009 | LG LFX25971ST Bottom Freezer French Door...
I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door.  You will need to have the filter replaced and that should take care of the problem.  But the filter should never have frozen in the 1st place.  You will need to call a qualified LG technician to see what's going on inside the refrigerator.
May 05, 2008 | LG LRSC-26922 Side by Side Refrigerator
LG LRSC-26922 Side by Side Refrigerator Logo
1,581 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
