Question about Punch Home and Landscape Design Suite for PC
In 3-d views, the screen is black unless I am in a mode moving the object. How do I fix this?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
The description sounds like a video card problem
Check this answer in the Punch Community Forum
These are the best resources for Punch Software solutions
Punch Software Community Forum
Punchhelpers Website
Learning Punch Software (R): Basic & Advanced Training
Learning Punch Software (R): Importing, Exporting and Printing
Punchhelpers at Facebook
Posted on Aug 16, 2013
2 Suggested Answers
  • 2340 Answers
SOURCE: In 3-d views, the screen is black unless I am in a
Get a better graphic card because your current graphic does not support 3-d view.
Update your present graphic card with the latest drivers updates or patches.
If it does not work you need to replace it with a better graphic card which support 3-d views.
Posted on Jul 18, 2010
SONY DSC-T1 CAMERA WHEN TURNED ON PREVIOS PICTURE SHOW UP FINE ON THE VIEW SCREEN BUT WHEN THE THE SELECT MODE SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO MOVIE MODE THE VIEW SCREEN IS MOSTALLY...
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
Mar 01, 2011 | Cameras
Whenever I switch to live view, the screen goes black unless I am moving the cursor.
I had this same problem. All the information I read said to run 32bit color. I switched mine to 16 bit and the 3D view worked great.
Sep 03, 2010 | Punch ! Professional Home Design Suite for...
Operating instructions for dsr pd177p sony video camera. I am not in postion to operate the camera, please guide how to operate the camera.
It is not very easy to say few lines to tutor ,but learn to use only by experience.Put the battery on for charging.Once fully charged slide the power switch to camera.Open the lens cap ,open the view finder display.Now you can see the picture on your screen.Set the camera to auto focus.show the camera to a white screen so as to white balance the camera.Now point at an object and do a trial Zooming using the auto zoom with your finger.The image will come closer and you can draw it to white screen.Having an object in view on the white screen,press the record button.Slowly move the zoom forward to get the right frame of the object.Press reccording button once again to stop.Repeat the process on different scenes.
Now shift the mode switch to play and rewind and play the reccorded portion.Practice.
Sep 02, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Jul 17, 2010 | Punch Home and Landscape Design Suite for...
Camera turns on, lens goes out, but it is black, see nothing through it or on lcd screen (yes, cover is off). There is no error messages, still takes pictures but just black. Can view previous pictures on...
It coud be a very common IRIS/Shutter stuck problem...this has been reported on lot of S3 IS & S2 IS cameras... just search for this on web and you'll find a temporary solution also (related to taking battery out in the middle of taking picture during a long exposure (15" in Tv mode), but for more permanent fix you need take it back to Canon service center
Aug 03, 2009 | Canon PowerShot S3 IS Digital Camera
My Pioneer 55 inch screen tv SD-P5553 has a solid black horizonta
This sounds like a picture mode issue. You maybe in a ZOOM mode. Try adjusting your set to FULL mode. If you are using a Sat receiver or cable box, some of these may have picture viewing mode as well, wich may need to be set in FULL or NORMAL viewing mode.
Good Luck!
Jan 18, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Black screen in shoot mode
The most common cause of this is a failed image sensor. Usually the playback mode will let you view pictures taken before the issue happened just fine and you will also be able to view the menu system just fine. When viewing the screen in an image taking mode, however, there is typically discolorations, horizontal or vertical lines, image bluring or distortions, or simply a black screen.
This situation, if caused by the image sensor, has to serviced and cannot be fixed by the user. If you are within your one year warranty and no user damage has been done to the camera, the camera will be fixed at no charge. If beyond the 12 month period however the customer may opt to have the unit repaired at a cost or take advantage of the Canon Loyalty Program and upgrade to refurbished S3 IS at an alternate discounted price.
Hope this helps.
Sincerely,
HeavyDLB
May 31, 2008 | Canon PowerShot S2 IS Digital Camera
JVC 700 dv: Both the monitor & view finder are pitch black, I can't see objects in front of the camera through the camera
Sorry, The bad news is you need to send it to JVC factory service for repair. The good news is they will fix it for free. It has a failed ccd which was a mass prduction problem. Go to www.jvcservice.com. You'll see your model number in the list. Just follw directions from there. Good luck! magic seadog
Aug 12, 2007 | JVC GRDX77 MiniDV Camcorder
Black screen
This is a system failure Tell Fuji Support about it but I fear any repair offer will be nearly the price of a new camera- unless of course it is still under warranty
Jul 12, 2007 | Fuji FinePix V10 Digital Camera
Black LCD screen and viewfinder in photo take mode
Sony (who bought KM) will fix this for free. http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Sep 05, 2006 | Konica Minolta DiMAGE A1 Digital Camera
Punch Home and Landscape Design Suite for PC Logo
243 people viewed this question
Top Punch Computers & Internet Experts
k24674
Are you a Punch Computer and Internet Expert? Answer questions, earn points and help others
