Question about IBM ThinkPad T20 2647 Notebook
I have had this computer plugged in for several days and the computer will not come on. It always has the green light for battery power on--what is wrong?
  • 64 Answers
Hi unplug the laptop take the batteryout, now plug in the power supply. see if the laptop turns on ,if not the power supply might off goting surged . try replacing with same kind thanks hope i been some help
Posted on Sep 27, 2010
  • cabell831 Sep 28, 2010
    What battery do I take out?
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
I was using my dell latitude d510 just fine the other day the only thing that was wrong is the battery wont charge so it always had to be plugged in. well from using the charger so much it finally stop...
The problem could be with the port the cord connects too. It could also be with the battery. If you take the battery out, and you still can't run on AC power, you need to replace the port. Take it to a computer/hardware shop and have it done.
Feb 24, 2011 | Dell Latitude D510 Notebook
Invacare m51 scooter. I just replaced the batteries in my dads chair. We charged it all night the first night and it ran great the next day. recharged it for several days after using it and now the battery...
Sweet you do not need to leave the charger plugged in for several days. Sounds like there is a charger problem When you first plug the charger in with batteries depleted you should be getting a red and yellow light with the yellow turning green when fully charged. now the charger (built in) could have become unplugged from the power module located in the rear of the chair behind the black cover. To get to it you have to remove the seat, shroud and batteries then using a phillips screwdriver and adjustable wrench remove the black cover. The charger cord will be the last one on the left with a small 4 pin white plastic plug make sure it is well seated in the power module. If it isn't loose then you have a problem with the charger or the circuit. Now if you know of a friend that has an off board charger for a chair or scooter that you can borrow you can charge the batteries using the charger port located under the front of the joystick Plug the charger into the port then into the wall socket and let er rip Charge until the light turns green overnite is a good habit to get into If the onboard charger is bad I would suggest you by an offboard charger (cheaper) Now if Medicare paid for your Dads Chair then they will pay for any repairs even batteries and you can contact the provider that your dad got the chair from to see if they will repair it Hope this helps
Feb 17, 2011 | Health & Beauty
My Presario 8000T power on then off
Hi there. Seems you already have a clue on what you are doing (good job). Try to test the system with another RAM stick. It may be a bad RAM, bad CPU or most likely, bad motherboard. But, before you change the motherboard itself, do the RAM test. It is the best shot. There is a device that you plug to the PCI port of *********** board but by the time you pay for it you are better off testing the RAM first. Good luck (please, if this helped, leave a comment).
Jan 07, 2010 | Compaq Computers & Internet
I have a 3507 emanchines computer.When I push start button all it does is show green light clicking . Then it will stop and the white light will below will blink 7-8 times. The green light will click about...
sounds like an issue with your motherboard or something like that...try resetting the motherboard by unplugging the power, taking out the battery of the motherboard inside the computer and pressing the power button several times to drain the power. then put the battery back in, plug in the power cord and try to start it up. if it doesnt work then ur gonna have to contact emachines because ur mobo is either defective or broken...
Nov 12, 2009 | eMachines W3507 PC Desktop
MX6448 won't boot; black screen.
It seems that you don't remove the battery when you use the Notebook. This practice shortens the life of the battery because, when you use the a/c adapter and the battery, your battery is alternately charging and discharging all the time. The cells in the battery eventually die.
From what you describe, it sounds like the power strip inside the Notebook (where you plug in the adapter cord) has been damaged and needs to be replaced.
Your computer is not a total loss. Just have that power strip and the battery replaced and your Notebook should be up and running again.
And, in the future, if you just remove the battery when your kid uses the computer, or if you are going to be using it for over 1 hour. Save the battery to use when you need the mobility.
Oct 10, 2009 | Gateway MX6448 Notebook
IBM ThinkPad R40
The battery indicator showing a yellow or orange indicates that the battery life is over. You may have to purchase a new battery.
Regarding the place where you can find information about these is that it is universal that the orange indicator means the battery is faulty.
Sep 13, 2009 | IBM ThinkPad T40 2373 Notebook
When the computer is turned on via the power button, the computer does not come on. When I check the LED indicators, the on/off indicator goes green, the battery power indicator is first orange, then...
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 30, 2009 | Computers & Internet
IBM ThinkPad T20 2647 Notebook Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
