Question about Whirlpool Washing Machines
How to clean the washer water intake screens?
  • 1,294 Answers
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Water shd be in good pressure at faucet. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Rate me pl........ if helped.
Posted on May 30, 2008
Washing machine is working as usual but water keeps coming out even though it had long finished and is off.
sounds like the water intake value is stuck open Try cleaning out the water inlet screens ware the water lines come in to the washer
Sep 20, 2015 | Bosch Washing Machines
How do you clean a washer hose
If you mean the water supply hoses, usually the intake screen becomes plugged with debris from the house water supply. The screen is removable with a small screwdriver or other small tool. Sometimes it helps to just reverse the ends of the hose and place the washer end into a sink or bucket. There should be a screen on each washer entrance connection that can get plugged as well. Hope this helps!
Oct 14, 2010 | Washing Machines
The screen on my coldwater feed keeps rusting up
No, don't poke it through. It will clog elsewhere. Clean the intake screen completely. Buy a $3.00 in hose screened washer. Put it in the hose end connected to your taps. The reason cold clogs and not hot is that the rust settles in the bottom of the hot water tank and doesn't get pushed thru the lines. The cold water is a direct feed. Clean the newly installed screen monthly as your supply taps are way more convenient than the connections to the water inlet vavle at the back of the machine.
Jun 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have had my washer a little over 15 years. It runs great but it takes way to long for the cold water to fill. We checked the incoming hose, it is not kinked and does not have build-up and water pressure...
depending on how hard you water is. Sediment will build up in hoses and intakes over time. Calium and rust. has there been a water main break in your area prior to problem start? Try back flushing intake and check filter screen at intake also
Mar 09, 2010 | Washing Machines
Water goes in very slow. Cleaned the intake filter where the hoses connect.IS the valve worn out to where it does not open all the way?
Check if the volume of water supplied to the washer from the water line through the hoses attached to it is good. If yes, the screen inside the water-inlet valve if it is clean. If clean, the water inlet valve is defective and you need to replace it. The water inlet valve is located inside the washer on the upper back portion. It is where the water supply hoses are attached to.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore HE3 Front Loader Washer Cold Water Intake problem
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool LSQ9500LQ0 stops runs only for about 2 minutes
Try this first..Same thing happened to me yesterday..
I pulled the washer away from the water source..unscrewed the water lines from the water intake (not the washer)..there is a screen in the both hot and cold screens were filled with debris..after cleaning the screens the washer works just fine..try this easy fix before you start looking into things like the motor or a switch somewhere...
Dec 19, 2008 | Washing Machines
No hot water reaching the tub
hi thanks for the question if you cleaned the screen and no hot water i would replace the water valve thanks the appliance doc
Sep 27, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
A display of hf, and the water intake piece
no way to unclog other than removing sedimet from screen assy. internally nothing need to replace.inlet watervalve 1 piece for both hot and cold water.
Mar 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal De
