Question about Sony VAIO VGN-SZ440 Notebook
Microsoft WPD FileSystem Volume Driver message Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
  • wmj9 Sep 27, 2010
    This was on a Sony VGN-FZ160E laptop - couldn't find the model in the choices to make. Vista Home Premium. I went to device manager, uninstalled the Microsoft WPD FileSystem Volume Driver - restarted the computer - checked Portable Devices and on start up the computer had reinstalled the Volume Driver twice, but apparently working this time. I found your site because of the Sony DVD RW AWG540A ATA Device error/not working. Your solution I found worked wonderfully. But why all the errors/devices not working to start with.
    Sergeant:
    Champion:
  • 214 Answers
Hello.
It seems you have a faulty driver.
Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Method 1. Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again. Here is how: First, please disconnect all USB devices and then perform the following steps:
1. Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
3. Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall . Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action , and then click Scan for hardware changes . Follow the instructions.
Method 2. Revert to the most recent successful registry configuration This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
With regards FIXYA team **Please post your feedback and Vote if the problem resolved as per your satisfaction**
Posted on Sep 27, 2010
Canon FB630u problem
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolution
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Try these options:
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard. Click Uninstall, and then click Scan for hardware changes to load a usable driver. Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true)The registry information applies to Windows XP.
Mar 01, 2008 | Canon CanoScan FB630U Flatbed Scanner
Wpd can't load
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
May 01, 2012 | Microsoft WPD FileSystem Volume Driver
This device cannot start. (Code 10)
HI,
Information as from the Microsoft website:
Code 10
If the device has a FailReasonString value in its hardware key, that string is displayed as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
This device cannot start. (Code 10) Recommended resolutions
Update the driver
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
View the article in the Microsoft Knowledge Base
For more information about Code 10-related errors , click the following article number to view the article in the Microsoft Knowledge Base:
943104 (http://support.microsoft.com/kb/943104/ ) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers For further details: http://support.microsoft.com/kb/310123
Aug 25, 2010 | Microsoft Computers & Internet
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you should uninstall and then reinstall the hardware device. (Code 19)
Try these options:
•Click Uninstall, and then click Scan for hardware changes to load a usable driver.
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
Hope it helps.
Jul 10, 2010 | Microsoft Windows Vista Ultimate Edition
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP
hope this helps
please leave feedback
thanks
Robb
Apr 21, 2010 | Computers & Internet
My computer (Vista 32-bit) does not recognize my Canon Eos Xs now. It did last week. I looked it up on Control Panel/System/Devices and I see this message "Windows cannot start this hardware device because...
Sounds like you may have some corruption beginning on your hard disk - try running CHKDSK /F from an administratively-enabled command prompt. It will prompt you to reboot, then it will run a consistency check on the disk and its filesystem upon booting.
Feb 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP.
Good Luck .. !!
Nov 22, 2009 | Acer Aspire 5315 Notebook
Code 19 error on ibm windows XP PC...neither the DVD or Cd drive are recognized or able to perform any functions.
Aug 20, 2009 | Office Equipment & Supplies
Error Messages
CAN I CHEQ THE THE WARRANTY?
Nov 17, 2006 | LG (GSA-4167B) DVD RW Dual Layer Burner
Sony VAIO VGN-SZ440 Notebook Logo
1,339 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
