Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My gas dryer takes too long to dry
When i turn on the dryer it dries good,but after 60 seconds the heating element turns off
  • Anonymous May 24, 2008
    THE GAS HEATING ELEMENT TURNS ON AND AFTER 60 SECONS , IT TURNS OFF, AND THEN AFTER 12 SECONDS IT TURNS BACK ON AND SO ON! WHAT COULD BE THE PROBLEM? THANKS!!
  • 41 Answers
Maybe I'm not understanding the question, but you said it dries good. Does that mean UNTILL the heating element turns off? If this is the case you will want to check the thermistats with an ohm meter. If they are ok replace the two solenoids located on the gas valve. You can go to the parts store first and buy them if you're not sure what they look like.
Posted on May 23, 2008
Dry takes a long time to dry cloths
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 28, 2012 | Kenmore Dryers
Clothes dryer doesn't heat
Nov 26, 2011 | KitchenAid Dryers
The dryer does not dry. No heat. I took off the bottom plate and turned on the dry. An electrical element turned a bright orange for a few seconds and then darkened. No gas went on.
Because you have a gas dryer, your problem is probably caused by the ingition panel, the electrical element that you saw turn a bright orange. Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat.his is what you described when you said the element only lit for a few seconds. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 24, 2011 | Dryers
Dryer is taking longer to dry. what used to take 60 minutes now takes 90-120. I took off the back panel and the lint shoot. both were clean. The air blows out the duct with good velocity. Hot air comes...
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Feb 04, 2011 | Dryers
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Dryer takes hours to dry
sound like you dry not heating,might need to replace the element
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
Dryer will not heat-up, clothes stay wet even after hours of drying! gas is on, gas bill payed,turning needlessly, no drying.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Nov 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
